What fuel do you use in your Saito engines
Tower Hobbies
Logged in as Guest
  Printable Version
XYZ-26cc Gas Engine
Seller:  XYZUSA
Details:   $219.00   |  4/26/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> What fuel do you use in your Saito engines
Page: [1] 2   next >   >>
Login
What fuel do you use in your Saito engines - 10/18/2007 2:21:13 PM
norcal sloper
Status: offline
Hi,
I resently purchased a Saito FA-100 and was talking to a couple of guy's at the field that said to make sure I used a fuel that has "castor", I had planed to use Powermaster YS/Saito 20/20, but this fuel doesn't have castor, what do you guy's use ? Thank you
       Post #: 1
RE: What fuel do you use in your Saito engines - 10/18/2007 5:36:11 PM
JPMacG
Status: offline
I've used S&W 15% nitro with 2% castor and 18% synthetic. I've also used Cool Power 15% nitro 20% synthetic. Both seem to run fine. The Cool Power costs a few dollars more.
(in reply to norcal sloper)
       Post #: 2
RE: What fuel do you use in your Saito engines - 10/18/2007 5:50:51 PM
hauckf
Status: offline
In my Saito 72 I use Coolpower 15% that my club buys in bulk. I add a few oz of Klotz Benol to bump the oil up to about 19% No problems.
(in reply to JPMacG)
       Post #: 3
RE: What fuel do you use in your Saito engines - 10/19/2007 3:09:28 AM
XJet
Status: online
Yep a few percent of castor will extend the life of your cam/lifters and also provide some valuable extra protection against corrosion of your bearings.
I use Coopers Fuel -- it's like crack cocaine for model engines :-)
_____________________________
When I'm not here, I'm at RCModelReviews
(in reply to hauckf)
       Post #: 4
RE: What fuel do you use in your Saito engines - 2/6/2008 8:02:10 AM
Delta3
Status: offline
If any one bothered to read the manual for saito engines you would know that the warranty is voided if you use castor oil in their engines.
(in reply to XJet)
       Post #: 5
RE: What fuel do you use in your Saito engines - 2/6/2008 1:44:04 PM
dant-RCU
Status: offline
quote:
ORIGINAL: Delta3
Really?? Funny, the manual that came with my Saito R325 warranty on Page 21 makes no mention of that fact. In addition, on Page 13 the manual specifically states that a
"castor/synthetic" mix is the preferred fuel. Obviously, I DID READ my manual!
The manual DOES state that fuels containing ALL castor are NOT recommended however.
Copies from MY Saito manual follow:
From Page 13 - regarding fuel:
"1. Use a high quality airplane fuel
like Omega or Powermaster mix
at 10-15%. The use of all castor
oil for lubraication is not recommended.
A synthetic castor mix is the preferred lubrication."
From Page 21 - Saito Warranty
CONSUMERWARRANTY AND REPAIR POLICY
"Saito engines are guaranteed against
workmanship and manufacturing
defects for a period of 3 years from
the original date of purchase. This
warranty is limited to the original purchaser
of the engine and is not transferable.
Warranty repairs will NOT cover:
• Normal Engine Wear
• Damage due to insufficient
maintenance
• Damage related to over revving if
engine due to small prop size or
unreasonable use
• Rusted Bearings
• Crash Damage
• Damage due to use of improper fuel
and/or glow plug
• Damage due to lean runs such as
rusted bearing, seized connecting
rod or piston, etc.
• Damage caused by foreign objects
(dirt or broken glow plug filaments)
• Damage caused by unreasonable
mounting or running conditions
(dust, insufficient cooling, improper
mounting, improper propeller size
of lack of balancing, etc.)
• Damage due to improper
disassembly
• Modifications of any kind"[/size]
Not sure exactly where you got the idea that Castor Oil will void the warrenty unless you are talking about 100% castor. To just say the warranty is
void if one uses castor is not true based on Saito's own recommendation and is grossly misleading.
I sure hope this does not start another "hang wringing and pants wetting session" regarding the use or non-use of castor oil in fuel!!
I use a castor/synthetic mix in both my Saito's - the R325 Radial and a 90T Twin.
Dan
< Message edited by dant-RCU -- 2/6/2008 5:31:00 PM >
Dan Taylor
American Turf Flyers, Inc.
(in reply to Delta3)
       Post #: 6
RE: What fuel do you use in your Saito engines - 2/6/2008 7:20:00 PM
Red B.
Status: offline
I run all my sport engines, mostly Saito and OS, on a brew of 15% syntetic oil (Aerosave), 5% nitro and the 80% methanol.
Using a modern syntetic oil I see no reason to add castor oil.
/Red B.
       Post #: 7
RE: What fuel do you use in your Saito engines - 2/6/2008 7:26:37 PM
Red B.
Status: offline
quote:
ORIGINAL: XJet
Really? By how much will cam/lifter life be prolonged?
My oldest Saito, an .56 has been run for more than 230 hours running on fuel containing 15% syntetic oil (Aerosave), 5% nitro and 80% methanol.
So far I have not noticed any wear. Even the bearings are the original ones.
/Red B.
(in reply to XJet)
       Post #: 8
RE: What fuel do you use in your Saito engines - 2/6/2008 7:29:46 PM
XJet
Status: online
quote:
ORIGINAL: Red B.
Ah.. but I was addressing our US friends who (with the exception of Coopers) only have some rather poor synthetics to choose from. There's no way I'd run a Saito on Morgans or Klotz synthetics without a few percent of castor.
Just check Bill Robison's Saito Notes for pictures of what these "lesser" oils will do to your camshaft over time if you don't add a little castor ;-)
(in reply to Red B.)
       Post #: 9
RE: What fuel do you use in your Saito engines - 2/7/2008 1:57:19 AM
Jezmo
Status: offline
quote:
ORIGINAL: XJet
quote:
ORIGINAL: Red B.
Nail on the head. I have two Saito's and add castor to my fuel if it's not already in there. I normally use 20% Nitro Cool Power, Byrons, Omega, Power Master, Rich's brew, Wildcat, or Magnum. We have no source for Coopers that I am aware of in my city and shipping is far too expensive to justify ordering fuel direct from them. I like his product but he needs someone in the Houston, Texas area to sell it. I'm there if he does.
Raptor 50 V2 OS 50 Hyper, T-Rex 450XL CDE, Spektrum DX7, SuperTigre OS FOX Saito Enya Jett TT
(in reply to XJet)
       Post #: 10
RE: What fuel do you use in your Saito engines - 2/7/2008 1:44:06 PM
Fuelman
Status: offline
quote:
ORIGINAL: Jezmo
quote:
ORIGINAL: XJet
quote:
ORIGINAL: Red B.
Jezmo,
Contact us via e-mail.
quote:
Hi,
I prefer to use a bit of castor in four strokes but thats just me. I will mention that I run almost any fuel I have left over from blending through my 4 strokes. I just tune accordingly to the fuel and go fly. I have run all synthetics, all castor and everything in between in four strokes with zero problems. A bit of castor will not hurt a thing and will only help reduce pitting on the cam lobes and lifter faces over years of running.
NONSENCE
Fuelman
Cooper Fuels LLC
(in reply to Jezmo)
       Post #: 11
RE: What fuel do you use in your Saito engines - 2/8/2008 3:36:23 PM
blw
Status: offline
quote:
ORIGINAL: Red B.
quote:
ORIGINAL: XJet
Bill provided good close up photos of cam wear with and without castor.
While some synthetics are quite good, none offer the same protection as castor at higher temps.
The ultimate responsibility of pilots is to fulfill the dreams of the countless millions who can only stare skyward...and wish.
       Post #: 12
RE: What fuel do you use in your Saito engines - 2/8/2008 6:37:27 PM
XJet
Status: online
quote:
ORIGINAL: blw
Mind you, the cam/lifter interface isn't exactly a "hot spot" in a 4-stroke engine. In fact this area runs relatively cool -- so the perceived hi-temp benefits of castor probably have no effect at all there.
What's needed is a lube with good film strength -- which some of the *advanced* synthetics do seem to have.
(in reply to blw)
       Post #: 13
RE: What fuel do you use in your Saito engines - 2/18/2008 7:42:41 AM
