XJet -> RE: What fuel do you use in your Saito engines (2/25/2008 3:19:58 AM)
quote:
ORIGINAL: kranie What I meant to say was that with every design there are trade offs. The Saito becasue of how it is designed builds up more heat- there is less metal around the piston area. Some how that heat needs to be delt with. Lubrication and pushing more fuel (that contains the oil) thru it is how Saito deals with it. As a result they have a light, high performance engine. Why do you think that less metal means higher temperatures? Once the engine reaches operating temperature, it wouldn't matter if the piston was solid aluminum or a lightweight skirted one. And don't forget that the Saito is AAC construction so it actually does a *much* better job of staying cool than ABC or steel-sleeved engines like the OS. The less metal between the "fire" and the ambient air, the faster the heat will conduct away and the engine will stay cool. With most 4-strokes, the combustion heat must first be conducted by the steel liner (not such a good conductor of heat) then cross the interface between the liner and the aluminum crankcase casting, then pass through the aluminum to the air. By comparison, the Saito has no steel liner so the heat of combustion is conducted directly to the fins where it quickly transfers to the propwash/ambient air. One thing I did notice with my Saitos is that they seem to run *cooler* than my other 4-strokes. The only thing that made me a *little* hesitant about using low-oil ratios with Saitos is the lack of a bronze bush in the conrod. However, this doesn't seem to have been any problem in practice.
