MRDEAD
NY, USA Status: offline
Hi all, did any one notice that they had to put in up thrust on a Da-85? Also for curiousity what are some weights out there? Mine is without pilot or wheelpants and no spinner 20.5 pounds dry. Gear on plane is two 2 cell 2100 thunder power for reciever, one 2 cell 2100 for ignition w/ fromeco reg,3 smartfly switches, smartfly EQ6 w/ turbo reg, JR9100 reciever, hitec 5955's w/ JR 8711 for rudder, DA-85 W/ slimline Pitts 1 servo for throttle and choke, carbon wing tube(troy built models tbm)don't forget to cut the length, xoar 26x10 2 blade prop. I got 11 flights on it. It's ballistic!!!!!!!!! out of box Da-85 ran strong haven't touched the needles yet 10 min flights less than a half of tank gas used each flight, scary !!!! I'm tempted to switch to a 20 ounce gas tank w/ gas stopper.[/size]
