RE: NEW Hangar 9 85cc SU-26MM Sukhoi
Tower Hobbies
Logged in as Guest
  Printable Version
Composite-ARF Extra 330L 2.3M ARF - 3.0 - ARF
Seller:  TheEdge
Details:   $1,000.00   |  10/3/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> TEAM RCU >> TEAM RCU - Mike McConville >> RE: NEW Hangar 9 85cc SU-26MM Sukhoi
Page: <<   < prev  2 3 4 5 6 7 8 9 [10] 11   next >   >>
Login
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 7/8/2008 11:26:40 AM
BaldEagel
Status: offline
You could find that the exhaust restriction from the Pits type silencer is causing a back pressure and resulting overheating, go for a cannister it may help.
Mike
_____________________________
No matter what anyone says 100% is the maximum you can get.
(in reply to RICK9303)
       Post #: 226
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 7/8/2008 5:57:36 PM
MRDEAD
Status: offline
Hi all, did any one notice that they had to put in up thrust on a Da-85?
Also for curiousity what are some weights out there? Mine is without pilot or wheelpants and no spinner 20.5 pounds dry. Gear on plane is two 2 cell 2100 thunder power for reciever, one 2 cell 2100 for ignition w/ fromeco reg,3 smartfly switches, smartfly EQ6 w/ turbo reg, JR9100 reciever, hitec 5955's w/ JR 8711 for rudder, DA-85 W/ slimline Pitts 1 servo for throttle and choke, carbon wing tube(troy built models tbm)don't forget to cut the length, xoar 26x10 2 blade prop.
I got 11 flights on it. It's ballistic!!!!!!!!!
out of box Da-85 ran strong haven't touched the needles yet 10 min flights less than a half of tank gas used each flight, scary !!!! I'm tempted to switch to a 20 ounce gas tank w/ gas stopper.[/size]
       Post #: 227
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 7/9/2008 1:40:46 AM
Andrew_S
Status: offline
Thanks for the replys. That pitts muffler did cut a lot of ower away from the engine Ihad to richen both needles almost 1 1/2 turns to get it to run. I just cut the end of the muffer off and the 2 outlets are all the way to the top inside of the can part. I cut them off and I'm gonna weld the end back on and go from there.....
What do heli''''s and ceiling fans have in common? When the blades stop turnin, You start sweatin ! ! !
(in reply to MRDEAD)
       Post #: 228
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 7/9/2008 11:47:56 AM
BaldEagel
Status: offline
quote:
ORIGINAL: MRDEAD
Mike
       Post #: 229
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 7/9/2008 9:01:37 PM
Andrew_S
Status: offline
What kind of issue are you having? I noticed with mine it wants to head toward the ground only when I apply full throttle at level flight. Nothing drastic though, also mine I had to put in several clicks of up trim.
(in reply to BaldEagel)
       Post #: 230
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 7/10/2008 12:12:28 AM
MRDEAD
Status: offline
I put in some washers behind the da-85 to give it up thrust because mine too would go towards the ground when throttle was applied and when in KE, it would go toward belly. After the washers were put in it does it a lot less about half way less. I'm going to do one more washer on each side to give it more up thrust. I also have it cg'd at 8 ". I'm going to in time make it more tail heavy. Maybe 8 and half inch's back
(in reply to Andrew_S)
       Post #: 231
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 8/13/2008 1:13:17 AM
wardie
Status: offline
I have one of these Sukhoi's with a 110 BME in it. It is the all time best H-9 design in my opinion. Mine weighs 19lbs dry with one 3000 2s lipo for the receiver and ignition. It turns a 26X10 NX prop at 8400 on the ground. It truly is the best multi purpose plane I have had.
       Post #: 232
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 8/13/2008 1:20:47 AM
wardie
Status: offline
I have to show my home made exaust, lawn mower mufflers drilled out on the BME stacks.
Click to see fullsize image.
Click for fullsize
(in reply to wardie)
       Post #: 233
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 8/13/2008 4:18:51 PM
flatlandmike
Status: offline
I think its time to get a buffing wheel for those welds. Make em shiny
www.jerseymodeler.com
Special thanx to The Crew Mike B. Jim Z. Ed J. Jim S.
       Post #: 234
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 8/13/2008 4:43:07 PM
bjamesjr
Status: offline
quote:
ORIGINAL: wardie
Can you say overpowered:O WOW
NorthEast IMAC Contest Coordinator
       Post #: 235
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 8/13/2008 5:41:48 PM
flatlandmike
Status: offline
Hovers at idle lol.
(in reply to bjamesjr)
       Post #: 236
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 8/15/2008 10:43:32 PM
wardie
Status: offline
The cowl hides the welds but you are right, I should have cleaned them up.
I am thinking of selling the two planes and my van. Time to go bigger....
Click for fullsize
Click for fullsize
(in reply to flatlandmike)
       Post #: 237
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 8/30/2008 6:03:59 PM
Aerozona
Status: offline
Hey Mike...I'm about half way done with my new Sukhoi SU26MM and ready to start thinking about my exhaust system. I have read the forums and see a couple of different views on what to use. I want to use a canister muffler system and was wanting to know your suggestion on the right canister muffler to use with my Sukhoi / DA-85 combo? Any help here will be fully appreciated.
"If your plane goes up, it WILL come down...your choice of decent is CRITICAL"
(in reply to MMcConville)
       Post #: 238
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 8/30/2008 7:26:23 PM
dptp9lf
Status: offline
quote:
ORIGINAL: wardie
Beautiful setup... I think you're right though... you've outgrown your van. LOL
Cheers,
Lyle
Lyle
       Post #: 239
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 8/31/2008 10:11:34 AM
Andrew_S
Status: offline
Get yourself one of these..........Is that exhaust heavy and how loud is it?
Click for fullsize
Click for fullsize
< Message edited by Andrew_S -- 8/31/2008 10:15:14 AM >
(in reply to dptp9lf)
