RE: NEW Hangar 9 85cc SU-26MM Sukhoi
Tower Hobbies
Logged in as Guest
  Printable Version
35% Wild Hare Sukhoi/DA-100 RTF - RTF
Seller:  somethnextra
Details:   $3,900.00   |  10/1/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> TEAM RCU >> TEAM RCU - Mike McConville >> RE: NEW Hangar 9 85cc SU-26MM Sukhoi
Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
Login
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 12/4/2007 8:34:30 PM
MMcConville
Status: offline
The differences in this Suk vs the older H9 SU-31 are too numerous to list. The list of common parts is much shorter.
1) Cowl
Thats it.
The Hangar 9 on the cowl is a sticker that isnt factory applied. Its supplied on a decal sheet.
_____________________________
Mike McConville
Horizon Hobby
(in reply to TheEdge)
       Post #: 26
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 12/22/2007 1:40:37 PM
downwind180
Status: offline
Mike, I have a 3w 75ius currently not attached to anything. How do you think It would perform it the su-26mm sukhoi? I would prefer the DA but this what I have for now.
(in reply to MMcConville)
       Post #: 27
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 12/26/2007 11:19:27 PM
Launch Pad McQuack
Status: offline
Mike you mention the cowl is the same as the SU-31. I broke my gear on a hard landing. Will the new SU-26 gear fit the old Sukhoi?
I have over 150 flights on the SU-31 and love it. I am sure with the lighter wing loading this will be a winner to. Keep up the great work.
       Post #: 28
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 12/29/2007 7:38:25 PM
flytime56
Status: offline
Mike,
For the MTW cannister, is it internal like the small 27% extra or external? Any pictures of the cannister installation?
Any updates on more videos, pictures, or manual online?
       Post #: 29
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 12/29/2007 8:10:39 PM
Flyjets
Status: offline
Hey Mike
Nike how is the Single JR8711 doing on the Rudder???
Will she Knife Edge at speed any Blow back?
Ian
RCU Moderator
Management is doing things right; leadership is doing the right things
(in reply to flytime56)
       Post #: 30
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 12/30/2007 12:08:47 AM
diamondave
Status: offline
i have a zdz80 without a home, had it on a comp arf at 22.5lbs and was plenty of power with a 26-8 cf prop, anyway lost the plane , i have been looking at the sd33% yak and then i saw this baby, anyone care to speculate which may be a better 3d platform? specs are similar with this sukoi being a tad longer and a bit more wing area, both good things, just would like to hear some opinions, i am planing to get one or the other....any more vids or pics of this other than whats on horizon site???
(in reply to Flyjets)
       Post #: 31
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 12/30/2007 12:52:19 AM
MMcConville
Status: offline
Pipe is internal. Similar to the 27% 260. 1 x 8711 on rudder is plenty. No blowback at any speed.
Mike McConville
Horizon Hobby
(in reply to diamondave)
       Post #: 32
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 1/3/2008 7:51:27 PM
les40
Status: offline
Mike,
I've seen two posts on RCU asking your opinion on how the 3W 75i would perform in this airplane and you haven't answered either. Any thoughts?
Les
       Post #: 33
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 1/3/2008 8:28:04 PM
MMcConville
Status: offline
Only that I think I dont have a clue. Havent owned or run a 3W engine in 9 years.
Mike McConville
Horizon Hobby
(in reply to les40)
       Post #: 34
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 1/3/2008 11:06:26 PM
serge1
Status: offline
Mike,
Any infos about release??
Serge
       Post #: 35
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 1/3/2008 11:18:20 PM
MMcConville
Status: offline
Yes. Were delayed a little and it will be mid feb.
Mike McConville
Horizon Hobby
(in reply to serge1)
       Post #: 36
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 1/7/2008 11:49:45 PM
Maged
Status: offline
Hi Mike, A friend an I have just decided to go for your new SU-26 and will make the order from Horizon next week. The decision was largely based on how great my Extra 260 is that I got a couple of months ago.
I have a question for you though... how would the SU-26 fare with the DA-100? would the wing loading go through the roof? would the performance deteriorate? could we fit the Da-100 into the cowl?
       Post #: 37
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 1/8/2008 12:00:32 AM
MMcConville
Status: offline
The spark caps would poke through the cowl. It would be heavier but whatever the diff is in the 100 vs the 85. More power than the 85 isnt needed unless your flying at like 12000 feet though
Mike McConville
Horizon Hobby
(in reply to Maged)
       Post #: 38
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 1/8/2008 8:03:52 PM
Maged
Status: offline
Thanks Mike. we're now sold on the DA-85. want to keep the wing loading downas much as possible. What would you recommend for props to use for arresti aerobatics and / or 3D?
       Post #: 39
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 1/8/2008 8:36:50 PM
Maged
Status: offline
does it come with that fantastic metallic blue spinner? if not where can i get it from.
(in reply to Maged)
       Post #: 40
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 1/12/2008 8:18:11 PM
flybye Steve
Status: offline
Hey Mike, I have the new Su-26MM on order and I'm trying to get all of the equipment in before it arrives.
I'll be using the DA85 with the MTW 110 Canister but no one at Horizon could tell me which Header to buy. Can you advise on the Header? Also, is the DA 85 mounted inverted on this plane?
Thanks for the info.
