taygher
Joined: 7/30/2005 From: Tranås, SWEDEN Status: offline
Mike, The Moki 150 weighs around 9,15 Lbs (4300g) so it is much heavier than the DA-85. I believe it would be possible to balance the plane by placing batteries etc. as far back in the model as possible. My main concern is if the increased wing loading is a problem or not. Since the SU-26MM is your design perhaps you can tell if the planes structure is strong enough to handle the increased weight? I have seen the previous version of the H9 Sukhoi with a Moki radial engine on it somewhere on the internet, unfortunatly there were no info about the flight carachteristics or the models performance. This plane/engine-combination is not the most common one and there is not much information to find. Thanks, Lars
