RE: NEW Hangar 9 85cc SU-26MM Sukhoi
Tower Hobbies
Logged in as Guest
  Printable Version
28%EDGE540 40-50CC - ARF
Seller:  peakmodel
Details:   $329.00   |  11/3/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> TEAM RCU >> TEAM RCU - Mike McConville >> RE: NEW Hangar 9 85cc SU-26MM Sukhoi
Page: <<   < prev  3 4 [5] 6 7 8 9 10 11 12   next >   >>
Login
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 3/8/2008 12:58:22 AM
camss69
Status: offline
I just ordered my Sukhoi.
OK Mike I have both your planes, I bought this one because you said it's your best ever and I really like my 260.
_____________________________
Not a YAK.
(in reply to darryl-e)
       Post #: 101
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 3/9/2008 9:07:12 PM
bsipro
Status: offline
Well No plane yet !!!!
Mike,
I have a question about the RX /Servo battery setup.
I'm going to run 2- A123 batterys (2p-2300mAh) for the RX / servos. I have read that you don't have to regulate them just plug them in to the RX.
I cant find any spec. on the HD JR switchs. can they handle 7-10amp draws from the Servo's.
and what conector setup (deans - JR in to switch to RX) I see that Fromeco has some nice switchs and Sin city jets has a HD JR style switch with 18g. wire.
any thoughts and pictures would be great.
(in reply to camss69)
       Post #: 102
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 3/13/2008 11:25:00 PM
raptorflyr
Status: offline
Mike -
I just wanted to say WOW! I'm building two of these for customers of our local hobby shop. Building really is not the right term. I wish everything was this easy!
One question for you - the manual calls for an 58-85 engine. Have you had any experience or testing with this plane and the Evolution 58? The specs describe about a 1HP different between a DA-85 and the Evolution 58. Thinking it might still fly fairly well with the 58. Did you test this combo? Would it pull out of a hover?
Thanks a million - This is a great product and everything is top notch! Just love the pilot figure!!
(in reply to bsipro)
       Post #: 103
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 3/14/2008 12:57:40 AM
Andrew_S
Status: offline
Lets see some pics! ! ! !
What do heli''''s and ceiling fans have in common? When the blades stop turnin, You start sweatin ! ! !
(in reply to raptorflyr)
       Post #: 104
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 3/14/2008 8:20:38 AM
dubd
Status: offline
The Evo 58 can throw a 23" prop and the DA-85 throws a 27" prop. No comparison.
(in reply to Andrew_S)
       Post #: 105
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 3/14/2008 4:06:04 PM
raptorflyr
Status: offline
dubd -
I have got an Evo-58 and I am currently flying a 24x10 with a pitts-style muffler. The manual calls for up to a 26" prop. I have read several places that with a can/pipe, this motor really produces the horsepower. It currently is in my heavy (about 20 lb) 30% yak now and it flys overpowered. I realize the motor is no DA-85, but I think an 85 in a 33% plane is overkill anyway. A lot of guys at my field are now using the 85 in 35% airplanes and they still are unbelievable. Was just hoping to get Mike's take on if they did any testing with the Suk and the Evolution 58...
(in reply to dubd)
       Post #: 106
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 3/14/2008 4:51:55 PM
CptCliffhanger
Status: offline
good question!
Mike, the 58 on a pipe has got perform at least as good as a stock GT80! and that was th old H9 recomendation for th 33%rs
Go big or go HOME!!! http://lunatique.com/stephan
       Post #: 107
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 3/17/2008 7:12:33 PM
MMcConville
Status: offline
I havent flown the Suk with the 58 so I dont have any real world experience there. With the ppwer I've seen from the 58, I think it'll fly it well, but nowhere close to the power from the DA-85.
Mike McConville
Horizon Hobby
(in reply to CptCliffhanger)
       Post #: 108
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 3/21/2008 2:01:28 AM
bjamesjr
Status: offline
A couple of quick questions that I do not see in the thread
What if any is the header drop needed with the DA85
I am assuming the can is the MTW110 and not the MTW110K (which I have already)
NorthEast IMAC Contest Coordinator
       Post #: 109
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 3/21/2008 9:12:27 AM
Maged
Status: offline
I'm ordering my 85 and 110 from Airwild and they did not know which header drop was required for the SUKI. I told them that MM had developed the system with DA and the guys at DA would know what the SUKI needed but when airwild got back to me they said the guys at DA had no clue what they were talking about. There seems to be a lot of confusion on this.
Mike I guess we would all appreciate if you could fill in the blanks. thanks
(in reply to bjamesjr)
       Post #: 110
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 3/21/2008 5:09:56 PM
bmoranx
Status: offline
Mike - I completed this airplane with the acceptation of the pipe and all I can say is nice job man. Everything was bolted together and all travel adjustments made in less than 10 hours. I am not a fast builder, but I took the day off and finished it that same day. I feel this is a very easy airplane to assemble....
1. Can you please let us all know the header drop?
2. The manual specifies an MTW 100 can but you say you used the MTW 110. Was this a typo in the manual?
3. There are a lot of open holes up front that will let a lot of air into the fuselage. Should I cap off these holes with light weight balsa?
thanx/Bruce
(in reply to Maged)
       Post #: 111
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 3/21/2008 6:15:56 PM
serge1
Status: offline
Anyone know if the plane is out yet?? Still waiting for mine since december.
(in reply to bmoranx)
       Post #: 112
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 3/21/2008 9:59:52 PM
CIIdriver
Status: offline
The guys at DA told me, that Mike told them, that the header is a 12mm drop.
DA said they had put some on order with their vendor but it might be another month or so.
Is that 12mm correct Mike?
(in reply to serge1)
       Post #: 113
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 3/21/2008 10:41:34 PM
RICK9303
Status: offline
When I ordered my engine from DA, they told me use the flex 25mm drop header. I my self have only seen 3 different drops in headers, 0, 25mm, and 50mm. DA told me that you had to use the flex header, but were out of headers and 110 MTW canisters. Horizon told my LHS that a small shippment came in of Sukhois. Next shippment, end of March. I got ahold of a 25mm drop header, and MTW 110 canister from Troy Built Models, crossing my fingers that DA was right, as down loaded manual calls for MTW110 canister, not header drop. This should be put in the manual, or put a a setup sheet, for DA85 engine install. RICK
(in reply to CIIdriver)
       Post #: 114
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 3/21/2008 10:59:15 PM
