NEW Hangar 9 85cc SU-26MM Sukhoi
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> TEAM RCU >> TEAM RCU - Mike McConville >> NEW Hangar 9 85cc SU-26MM Sukhoi
Page: [1] 2 3 4 5 6 7 8 9 10   next >   >>
Login
NEW Hangar 9 85cc SU-26MM Sukhoi - 10/18/2007 4:12:38 PM
MMcConville
Status: offline
Guys, the info and video is here:
http://www.horizonhobby.com/Products/Default.aspx?ProdID=HAN1225
_____________________________
Mike McConville
Horizon Hobby
       Post #: 1
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 10/18/2007 7:01:50 PM
edgeman55-RCU
Status: offline
Very nice Mike.What motor did you have in the video plane?
(in reply to MMcConville)
       Post #: 2
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 10/18/2007 7:21:18 PM
MMcConville
Status: offline
DA-85 with an MTW 110 canister. Mej 27 x 10 TH prop
Mike McConville
Horizon Hobby
(in reply to edgeman55-RCU)
       Post #: 3
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 10/18/2007 8:58:43 PM
krayzc-RCU
Status: offline
Mike,
I am loving your re-released Cap on a DA-85 also only running one servo with the c/f goodies coming in at 21.5 lbs. I know this has to be another winner for you. That DA is a beast
smooth as silk!
       Post #: 4
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 10/20/2007 12:47:30 AM
capflyr
Status: offline
MIKE I LOVE YOU MAN, THIS IS JUST WHAT I WANTED FOR X-MAS KEEP UP THE GOOD WORK, I GOTA GO SWEET TALK THE OLD LADY.
(in reply to krayzc-RCU)
       Post #: 5
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 10/30/2007 1:36:48 PM
rkingmanila
Status: offline
hi mike, i have an older zdz 80 twin. would you suggest this motor for the sukhoi? i fly a bit of 3d and pattern.
(in reply to capflyr)
       Post #: 6
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 10/30/2007 10:14:52 PM
MMcConville
Status: offline
No experience with the ZDZ, but with the DA-85 it has plenty of power to spare, so less would still be very good.
Mike McConville
Horizon Hobby
(in reply to rkingmanila)
       Post #: 7
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 10/30/2007 11:07:45 PM
AEROSHELDON
Status: offline
I have two 8611a's and three 8711's... should i use the 8611a's in the elevators or ailerons?
What size servo arms, I need to order those...
Have fun and play nice!
       Post #: 8
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 10/31/2007 5:55:23 PM
MMcConville
Status: offline
I'm using 8611A on ail and elev and 1 8711 on rudd. I'd use the 8711 on ail and 8611A on elev given what you have. I use the aluminum JR servo arms.
Mike McConville
Horizon Hobby
(in reply to AEROSHELDON)
       Post #: 9
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 10/31/2007 6:18:46 PM
AEROSHELDON
Status: offline
Thanks Mike, I can't wait!
       Post #: 10
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 11/1/2007 4:05:53 AM
AEROSHELDON
Status: offline
Oh yeah, what battery sizes do you recommend?
< Message edited by AEROSHELDON -- 11/10/2007 2:07:17 AM >
       Post #: 11
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 11/1/2007 4:24:32 AM
MMcConville
Status: offline
I used 2 x 4500 mah Lipos on the rx and a 3rd on the ign. More than is needed, but the packs arent too heavy so I prefer to have plenty of battery
Mike McConville
Horizon Hobby
       Post #: 12
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 11/20/2007 8:07:36 PM
dptp9lf
Status: offline
Mike!
I'm waiting for mine to come... hope I get it by the end of the year!
Anyway, I'm putting a ZDZ Super 80 RV-J with a JMB can which is huge. It's about 83mm diameter and 24" from sparkplug to end. Will that header/can setup fit in the tunnel... i'm assuming it has a can tunnel?
Also, do you know if the Hangar 9 decal on the cowl is already attached when it comes or will that have to be installed?
Thanks Much!
Lyle
Lyle
       Post #: 13
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 11/20/2007 8:11:09 PM
AEROSHELDON
Status: offline
how do the stabs attach? I will have to remove them every time unfortunately...
(in reply to dptp9lf)
       Post #: 14
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 11/26/2007 10:38:44 PM
MMcConville
Status: offline
Its pretty tight in the can area. The MTW 110 fits (69mm dia) but there isnt a lot more room. The decal will be on a sheet not on the cowl.
The stab attached with two tabs under each stab (like the one on the 35% 260 x 2) attached to the fuse with a 4-40 bolt in each.
Mike McConville
Horizon Hobby
       Post #: 15
RE: NEW Hangar 9 85cc SU-26MM Sukhoi - 11/27/2007 3:39:37 PM
AEROSHELDON
Status: offline
Nice, that is the way to do a stab in my opinion!
       Post #: 16
