Super Tigre 3000 fuel
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> SuperTigre Engines Support >> Super Tigre 3000 fuel
Page: [1]
Login
Super Tigre 3000 fuel - 10/19/2007 3:21:02 PM
Steve
Status: offline
I have an older Super Tigre 3000 that has been on the shelf for a few years, but I am going to start using it again soon. I've alwaysed used 15% nitro in the engine, but don't buy it anymore. I now only use YS 20/20 fuel. Is this an ok fuel to use in the motor? I have an 18 X 8 prop and am at 5600 feet above sea level. Would a non idle bar plulg be better for this fuel - engine combo also? Thanks.
< Message edited by Steve -- 10/19/2007 3:22:00 PM >
_____________________________
AKA,, "The Spleen"
If you want to see my Super Power,,, pull my finger.
       Post #: 1
RE: Super Tigre 3000 fuel - 10/19/2007 3:29:32 PM
Bax
Status: offline
Your YS 20/20 fuel would have both too much oil content and too much nitromethane. The SuperTigre S-3000 was originally intended to be broken-in on fuel with about 15% oil content and then run on fuel with 10%-12% oil content after breakin. The engine runs best when the nitro is kept below 10% by volume. 0%-5% also work well. When using a low-oil content fuel, SuperTigre recommended that the oil be 100% castor oil, which is all they used in their engines. A castor/synthetic blend will work OK, too.
The problem with the high-nitro/high-oil fuel, like a 20/20 blend is that the high-nitro content will combine with the high-oil content and you'll likely experience detonation.
For a glow plug, we'd normally use an O.S. #8 plug, but many fliers have used the O.S. Type F sucessfully, too.
Bill Baxter, Manager Hobby Services/Futaba Service/North America
3002 N. Apollo Dr. Ste. 1 Champaign, IL 61822 USA
Service Phone: 217 398-0007
Email: hobbyservices@hobbico.com
(in reply to Steve)
       Post #: 2
RE: Super Tigre 3000 fuel - 10/19/2007 7:49:01 PM
Steve
Status: offline
Thanks. Is the OS type F a four stroker plug?
AKA,, "The Spleen"
(in reply to Bax)
       Post #: 3
RE: Super Tigre 3000 fuel - 10/22/2007 4:36:10 PM
Bax
Status: offline
Yes, the Type F plug is a 4-stroke plug.
(in reply to Steve)
       Post #: 4
RE: Super Tigre 3000 fuel - 10/23/2007 4:17:21 AM
Steve
Status: offline
I ran the engine today on 15% Moki/Tigre blend Magnum fuel and it worked out great for the test run. Now I have to put it in the air.
AKA,, "The Spleen"
(in reply to Bax)
       Post #: 5
RE: Super Tigre 3000 fuel - 10/26/2007 2:37:44 PM
Steve
Status: offline
I tried the four stroker plug in it yesterday and it seemed to run a little better and have a touch more power.
AKA,, "The Spleen"
(in reply to Steve)
       Post #: 6
RE: Super Tigre 3000 fuel - 11/13/2007 1:16:23 PM
sodbuster 1
Status: offline
BAX, can you reccomend a specific fuel that would be best to run in this engine?
Also have one of these like brand new but is a little gummy can you also tell me the best way to un-gum it?
Once you go Yak, you never go back......
Club Saito member # 610
(in reply to Steve)
       Post #: 7
RE: Super Tigre 3000 fuel - 11/13/2007 4:21:16 PM
Bax
Status: offline
To "un-gum" an engine, remove the rear cover and cylinder head and submerge it in fresh model fuel. After a few hours, old fuel residue should start to dissolve and allow the engine to become free.
For the large SuperTigre engines, but not the G-2300, you want to break it in using a fuel with no less than 15% oil content. Nitro can be 0%-10%, but 5% is really a happy medium. Once the engine's well-broken-in, you can go to a fuel with 10%-12% oil content and the same nitro content. All-castor oil is preferred as the lubricant at the low oil levels. Some fuel maker have "ST", "Super-T", or "SuperTigre Fuel" blends. They usually have the 10% oil content and low nitro.
(in reply to sodbuster 1)
       Post #: 8
RE: Super Tigre 3000 fuel - 11/13/2007 4:44:49 PM
sodbuster 1
Status: offline
BAX couple more questions if you don't mind .Never ran/used one of these. Have always used gas engines
Can you tell me what the performance specs on this motor might be?
Proper prop size for peak performance and power?
Weight class preferred for this engine with the idea that I prefer plenty of power in anything I fly?
(in reply to Bax)
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.766RCU3
