Pull start substitutes?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Nitro Stadium Trucks >> Pull start substitutes?
Page: [1]
Login
Pull start substitutes? - 10/20/2007 12:57:28 AM
zud00
Status: offline
I recently got a new Team Losi GTX. I am in the process of breaking it in but have already had problems with the pullstart. The first time I broke the string and the handle came off. The second time the end hook on the coiled spring broke and the spring unwound.
Is there an alternative to the pullstart? There is a sticker on the motor that says ".12 PD" I would like to use a rotostart if that's possible or something similar. What would I need in order to do something like this?
_____________________________
Savage X w/LRP z28 spec 3
Bash Big or Go Home!!!
       Post #: 1
RE: Pull start substitutes? - 10/20/2007 3:35:06 AM
DaveG55
Status: offline
Look up Tiger Drive and see if they make one for your engine.
Can you go bump start?
Any technology, sufficiently advanced, will appear as magic
(in reply to zud00)
       Post #: 2
RE: Pull start substitutes? - 10/20/2007 4:09:40 AM
Dawman
Status: offline
Bump start is the way to go . I hope you take it easy on that truck as parts will be hard to find .
< Message edited by Dawman -- 10/20/2007 4:10:52 AM >
(in reply to DaveG55)
       Post #: 3
RE: Pull start substitutes? - 10/20/2007 6:48:28 AM
Hoese37
Status: offline
that motor is a dynamite .12 pd. I think someone makes a rotostart for it. check HorizonHobby.com
Mike: "It's broken." Carter: "Just solder it."
Mike: "It's nitro." Carter: "Lean it
(in reply to Dawman)
       Post #: 4
RE: Pull start substitutes? - 10/20/2007 6:51:02 AM
MiamizFinest
Status: offline
quote:
ORIGINAL: Dawman
HELL YEA bump start is the way to go!!!!! u can find starter boxes for as low as 50 bucks
-= THE WORLD IS YOURS =-
       Post #: 5
RE: Pull start substitutes? - 10/20/2007 11:00:06 PM
zud00
Status: offline
I picked up the truck at a hobby shop that was going out of business so i got it for pretty cheap. I'll probably use it mostly at the track and hope not to break anything.
I'll check out the horrizon hobby webpage to see if they do infact make a rotostart for it. I already have the rotostart for my savage so if I could just get the part that mounts on the engine then that would be perfect.
How does a bump start work???
(in reply to MiamizFinest)
       Post #: 6
RE: Pull start substitutes? - 10/21/2007 12:39:24 AM
zud00
Status: offline
I found this: http://www.horizonhobby.com/Products/Default.aspx?ProdID=SUL689
Would this fit? If it does, what else would I need?
I'd probably need this wand: http://www.horizonhobby.com/Products/Default.aspx?ProdID=SUL686
Will that wand fit in my rotostart?
If it does fit, does it spin it the correct way? Or do all engines turn the same way?
Thanks for the help.
(in reply to zud00)
       Post #: 7
RE: Pull start substitutes? - 10/21/2007 12:48:54 AM
Dawman
Status: offline
All engines turn the same way . Not sure if the tiger drive will work with your roto starter . You are better off using a starter box anyway . To use a starter box you line up the chassis on the box and set the pegs to where the starter wheel will make contact with the flywheel on your engine . After setting it up , you place the truck on the box and press down which will engage the starter wheel and will spin the engine and start it using a glow starter attached .
(in reply to zud00)
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.469RCU1
