AllAboutFunHobbies
quote:
ORIGINAL: {GBI}Harryball quote:
ORIGINAL: AllAboutFunHobbies You can use WD-40, carb cleaner, or what I do when I want to totally clean the heck out of mine I take the wheels off, the electronics out and the engine off, spray the whole thing down with simple green take a tooth brush to loosen up the thick stuff and spray it down again, let it sit a minute then take it and rinse it off with the hottest water I can from the tap and it gets completelly clean. Yep, instead of spraying them off, i just put mine in the dish washer. Make sure when you are done to put some lub on the metal parts. Your good to go. I've done that too, that actually works awsome, then when your done(i forgot to add this part) I dry it with a blow dryer and THEN spray it down with WD-40 to coat everything. Of course you take off the engine and electronics before you do this and don't let your wife catch you doing it either could be the end of you and your nitro car, LMAO
_____________________________
Dealer for...Redcat Racing, Traxxas, Team Associated, Cen, Racers Edge, RD Logic, Bodies by Blue, HPI, Himoto USA.....etc
