RE: The Unofficial all things Jet drive thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> Speed - Electric >> RE: The Unofficial all things Jet drive thread Page: <<   < prev  186 187 188 189 190 191 [192] 193 194 195   next >   >>
Login
RE: The Unofficial all things Jet drive thread - 4/21/2012 5:24 PM
Quicksilver
Last Login: 5/11/2013
Status: offline
quote:
ORIGINAL: sundogz
Long time gone, Quicksilver,. IB3600 equivalent - 16cell? Wasn't the IB3600 a 6 or 7 cell (7.4 to 8.4v) NIMH with 3600mah capacity and a 30C (thereabouts) discharge rating? A 2S (7.4v) lipo now will give you much more capacity or run time than the NIMH for the same weight (or the same capacity for less weight). You will be surprised and happy. Welcome back!
I didn't buy packs. I made them so their two 8 cell packs. so whats that 6s-7s?
_____________________________
If you can imagine it....
Hide Signatures
(in reply to sundogz)
       Post #: 4776
RE: The Unofficial all things Jet drive thread - 4/21/2012 5:59 PM
sundogz
Last Login: 5/16/2013
Status: offline
16c NIMH at 1.2v/cell is 19.2v. A 1s lipo is 3.7v, so the closest match would be 5S (18.5v). This Turnigy 30C is a good buy and located at the U.S. Hobbyking warehouse.
Arpro Mono,Genesis,Tenshock Essenz, PowerJet Viper,ABC Jet Ski,TearInto Jet Sprint, Legend & Discovery Sailers, JetCat proto
Hide Signatures
(in reply to Quicksilver)
       Post #: 4777
RE: The Unofficial all things Jet drive thread - 4/22/2012 8:19 PM
Quicksilver
Status: offline
that isnt a bad price I might just buy that
thank you
Hide Signatures
       Post #: 4778
RE: The Unofficial all things Jet drive thread - 5/14/2012 1:43 AM
EdgardoJr
Last Login: 4/29/2013
Status: offline
http://www.youtube.com/watch?v=Wb_bgR78mCY&feature=g-upl
SCIENTIA MAXIME CUUM VIRTUTE "92 - DYNAM T-28 TROJAN - FMS MINI T-28 TROJAN
Hide Signatures
       Post #: 4779
RE: The Unofficial all things Jet drive thread - 8/5/2012 2:44 AM
Madmax160764
Last Login: 4/14/2013
Status: offline
NQD Jet boat dymo, new motor (4800Kv) and batteries Turnigy Nano-Tech 1.8
Hide Signatures
(in reply to EdgardoJr)
       Post #: 4780
RE: The Unofficial all things Jet drive thread - 8/5/2012 2:54 AM
diy-pro
Last Login: 11/8/2012
Status: offline
lovin it mad max sweet little jet drive :]]]
Hide Signatures
(in reply to Madmax160764)
       Post #: 4781
RE: The Unofficial all things Jet drive thread - 8/5/2012 6:36 AM
Madmax160764
Status: offline
NQd Tear-Into carnage bashing in pool.
< Message edited by Madmax160764 -- 8/8/2012 6:02 AM >
Hide Signatures
(in reply to diy-pro)
       Post #: 4782
RE: The Unofficial all things Jet drive thread - 8/28/2012 5:03 PM
pootis mcgootis
Last Login: 2/13/2013
Status: offline
Hi All,
Just ordered two KMB 28mm jet drives, always had an interest in building a dual jet hull. Any suggestions on a suitable hull? Interested in something that is widely available, even through HK is fine just nothing caught my eye. Any suggestions towards motor/batt combos would be much appreciated as well. Thinking a low kV motor with a higher cell count LiPo...
P
Hide Signatures
       Post #: 4783
RE: The Unofficial all things Jet drive thread - 9/19/2012 9:52 PM
Jay-Em
Last Login: 12/19/2012
Status: offline
Informative thread.
However, I am still somewhat in the dark about the Graupner Mini-jet, and the ideal motors to run it.
At the moment I use the mini-jet, coupled with a hobbywing 10t BL 550 ( an SC motor) and it runs nice, cool, I get about 20min on a 4ah lipo. Hobbywing SC 75amp ESC keeps cool too. All of it watercooled though.
All of it is custom fit in a 48cm Kyosho WaveChopper jetski.
Point is, I see all sorts of ideal RPM proposed for the tiny jet, but no definitive rpm. The 550 is a 3500kv. I run it on 2s, and it seems to get pretty close to the full 25000 rpm. It has a habitof spinning-out, but a little judicious throttle control fixes that nice. It rides a nice, stable 5 degrees nose-up when on-plane, no porpoising whatsoever, so the pump gets primed well.
Is that 25000rpm too much? The speed is a sedate 25km/h or thereabout, since I go quite a bit faster than the Bicycles on the adjacent path of my favourite pond.
I tried 3s, but that only made a lot of noise and cavitation, speed only marginally increased.
In tne past I have experimented with the advised speed500 race (I guess it is a 21t 540) a Speed600race and a 17t double corally. All of those variations ran well, not really fast, but got very very hot, and killed their magnets, despite watercooling. The BL 550 is the first motor NOT to cook or burn... Must have done something right there
It just made me wonder: is that 25000 the limit of what the little Graupner jet can effectively use? In other words, 30kph is the end. Higher speed needs a bigger jet?
Hide Signatures
       Post #: 4784
RE: The Unofficial all things Jet drive thread - 9/21/2012 3:41 AM
damfurst
Last Login: 4/28/2013
Status: offline
quote:
ORIGINAL: Jay-Em
There is only so much 19mm can do A bigger jet drive in the same size hull will make the hull go faster. This has been proven on the other jet drive thread with the Nqd tear into where some have put the bigger Graupner 29mm, Kehrer 28mm, and Abc Hobby 22mm. I hope this answers your question.
Hide Signatures
(in reply to Jay-Em)
       Post #: 4785
RE: The Unofficial all things Jet drive thread - 9/21/2012 2:04 PM
sundogz
Status: offline
quote:
ORIGINAL: Jay-Em
So far as the Graupner and NQD drives, I have been advising that 3000kv on 3S and 4500kv on 2S seems to be tops with a 20mm motor. That comes out to 33000rpms unloaded. So you can get a little more speed than you have attained so far. But to get more speed yet, you'll need to go to a larger jet as Damfurst said, or go to a larger motor which will push through the 'envelope'. Or both. The larger motors seem less prone to the kv limitations of the smaller motors - where, in the upper 1/4 of the throttle range more throttle results in more noise, not more speed.
Hide Signatures
       Post #: 4786
RE: The Unofficial all things Jet drive thread - 9/22/2012 3:40 AM
Jay-Em
Status: offline
hmm..okay.. The motor is a large 550. (3650/540L) meant for Stadium trucks, not a 20/380/400 class. it has plenty of oommph, It feels more like over-revving a too small prop.
Well.. I guess it's going to be Stabilit-hacking, and fitting a 28 Kehrer, then.
Ugh.. I had hoped to prevent having to cut'n grind away at the Stabilit mounds around the jet.. I only hope the not-so-impressive performance of the WaveChopper with a jet is not because of some design-flaw. Improbable, I know. I studied quite some Seadoos, and the kyo's hull is not bad at all, but one never knows.....
Hide Signatures
       Post #: 4787
RE: The Unofficial all things Jet drive thread - 9/22/2012 3:25 PM
sundogz
Status: offline
My ABC Hobby Jet Ski's were factory equipped with 550 brushed motors (I don't know the rpm range) but the swap for the 28mm brushless motor brought much more speed and with it some aeration problems (another story) so made quite a difference. But in all fairness, they have 23mm impellers which might have helped a bit as well.
Hide Signatures
       Post #: 4788
RE: The Unofficial all things Jet drive thread - 9/22/2012 4:33 PM
Jay-Em
Status: offline
Those ABC's seem to have been "put away" under the monniker "toy-grade", but, the more I read about them, the more impressing they become.
I searched e-bay, but the ABC's seem to be completely gone. Shame.
23mm You say? Hmm.. The Graupner is a 20mm. It could, indeed, explain the excessive aeration I get when putting 11.1v through the eazyrun 550..
Doesn't the ABC have some kind of baffle in the jet-exhaust? I distinctly remember a picture of it with some sort of rubber ring in the nozzle.
On another note: I fixed the spinning-out by copying a system straight from a Seadoo. Sponson-blades. It'll stíll spin-out when trying to turn really sharply on full throttle, but that's to be expected. Most speedboats do that. I am already happy enough that it'll corner at áll.
Hide Signatures
       Post #: 4789
RE: The Unofficial all things Jet drive thread - 11/13/2012 5:37 AM
BIG22BIRD
Last Login: 1/12/2013
Status: offline
well here is some updates, i have had a long r/c brake. and i finally put some batteries in my charger this morning, here are some progress pics. its dont now and loads of fun once again.
If it doesnt melt... its not fast enough!!!
Hide Signatures
       Post #: 4790
RE: The Unofficial all things Jet drive thread - 11/13/2012 5:39 AM
BIG22BIRD
Status: offline
some more progress, motor is mounted , shoegoo is my friend.
mounted the water pick -up. added some other stickers and a few coats of clear coat.
also added my grate.
i still need to mount my ride plate.
Hide Signatures
(in reply to BIG22BIRD)
       Post #: 4791
RE: The Unofficial all things Jet drive thread - 11/13/2012 5:40 AM
BIG22BIRD
Status: offline
Hide Signatures
       Post #: 4792
RE: The Unofficial all things Jet drive thread - 11/13/2012 6:05 AM
BIG22BIRD
Status: offline
here is my water outlet, i used the exhaust pipes, instead of a hole out the back.
http://www.youtube.com/watch?v=M9TCJrL4V_Y&feature=youtu.be
Hide Signatures
       Post #: 4793
RE: The Unofficial all things Jet drive thread - 11/13/2012 1:45 PM
sundogz
Status: offline
I like the driver - he looks ominous enough for sure. That boat will be another monster! The only reservation I have is the water through the headers is difficult to see to know if the cooling flow is sufficient. That is why I usually direct it up and out like a jet ski. Yep, shoe goo is good stuff, to be sure. Good job. Looking forward to a video of it in action.
Hide Signatures
       Post #: 4794
RE: The Unofficial all things Jet drive thread - 11/16/2012 1:00 AM
seehuusen
Last Login: 4/30/2013
Status: offline
hell yeah!! Looks great Big Bird I actually like the water out of the headers, hahaha Great ideas here
Hide Signatures
       Post #: 4795
RE: The Unofficial all things Jet drive thread - 11/16/2012 2:38 AM
SkR8Pn
Last Login: 5/17/2013
Status: offline
 Good to see V2 up and running,  nice work! I should start on my second big jet tear into also. A lot of lessons learnt after the first one! May it rest in peace...
SCX10 Truggyx2, Wraith
Ota R31, 16FM, D3.
Hide Signatures
       Post #: 4796
RE: The Unofficial all things Jet drive thread - 11/18/2012 3:42 AM
BIG22BIRD
Status: offline
here is a shot of my ride plate and the water exit.
Hide Signatures
(in reply to SkR8Pn)
       Post #: 4797
RE: The Unofficial all things Jet drive thread - 2/7/2013 11:05 PM
Vidjaya
Last Login: 2/7/2013
Status: offline
Hi.
I bad speak English, but I would like to ask in this topic.
Has built the boat. Weight with battery 2.2 kg, 590 x 180 mm. Time to swim 5 minutes. The speed of the gps 30 km / h. The boat is floating in 50% of the gas, if 100% of the gas, the rotation of the increase, and the speed of the no.
Jet 28-mm-Jet with short steering nozzle
http://www.jet-drive.de/index.php?page=shop.product_details&flypage=shop.flypage&product_id=9&category_id=4&manufacturer_id=0&option=com_virtuemart&Itemid=17
Motor Neu-Castle 1410 1Y 3800kv 4 Pole
http://www.amainhobbies.com/product_info.php/cPath/1_221_1889_1890/products_id/222734/n/Castle-Creations-1410-1Y-4-Pole-Brushless-Motor-w-5mm-Shaft-3800kV
Esc Turnigy Marine 180A Brushless Boat ESC
http://hobbyking.com/hobbyking/store/__8937__Turnigy_Marine_180A_Brushless_Boat_ESC.html
Battery Turnigy 5000mAh 2S 40C Lipo Pack
http://hobbyking.com/hobbyking/store/__10305__Turnigy_5000mAh_2S_40C_Lipo_Pack.html
Video
http://www.youtube.com/watch?v=53WCBOT_bLE&feature=player_embedded
Foto
http://forum.rcdesign.ru/f68/thread304846.html
I want to:
Swim of 15 minutes. (It is important)
Speed of 30 - 50 km/h.
Size of 600 mm.
Batteries 2S.
As you think:
Remake this boat? To build a new boat? What Motor to place? If the jet set 19 mm?
Very much I wait for your help.
Hide Signatures
       Post #: 4798
RE: The Unofficial all things Jet drive thread - 4/15/2013 2:41 PM
sundogz
Status: offline
Well, it has been a while since this tread has seen some action, so I'll show a recent project of mine. I purchased a used 24" nonstepped cat hull from a seller on ebay. I had been watching for such a hull for quite some time, since first seeing one for sale on another site a year or so earlier. It had the odor of a burned up speed control along with black discoloration under the canopy. The NQD drives I had would fit perfectly in the sponsons with a bit of work.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Vidjaya)
       Post #: 4799
RE: The Unofficial all things Jet drive thread - 4/15/2013 2:51 PM
sundogz
Status: offline
I prepped the jet drives by removing casting marks from inside, and reshaping the intake ramps. I used Shoe Goo this time (first for me) to install the drives in the hull, and it was faster and easier than epoxy. It took two applications, but the drive bodys are now a part of the hull. I've filled the previous holes in the transom and the former stuffing tube hole, sanded and primered the stern, installed the steering system using some heli parts I had laying around. I fabricated a servo mount where you can remove the servo by just cutting a zip tie, because a screwdriver would be difficult to get in there later on. I dremeled (is that a verb now?) down all those offending epoxy mounds from previous attachments and encounters and (though it doesn't look it in the photos) the deck is relatively smooth now. I've got to drill 4 more holes through the transom to facilitate a long hex screwdriver to more easily remove the motors, and I'll just cover the holes with hockey tape or a decal. And I need to install water pickups on the jets. Waiting on the esc's/motors and the SicRc couplers. Each jet will have it's own motor, cooling, esc and lipo, so will be semi-redundant to the Rx. If something should go wrong, it should make it back on the other jet (that's two 'shoulds', I know). I'm sticking with a single (med size) servo system for now, but am entertaining the idea of removing the steering nozzles completely, and going to Vector steering to see how effective that is. I've not seen a FE Cat hull done with jets low in the sponsons - I've seen 'em in troughs, and in the tunnel and none impressed me very much - other than to get me thinking of how to correctly pull it off. It works well for Ferry Boats, and they have zero turning radius! This boat fit the bill, what with no steps and sponsons just the right size for the NQD drives. I had to cut off the mounting tabs to fit them in
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 4800
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.113RCU1
