RE: The Unofficial all things Jet drive thread
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Boats >> Speed - Electric >> RE: The Unofficial all things Jet drive thread
Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
Login
RE: The Unofficial all things Jet drive thread - 11/1/2007 1:29:04 PM
DRAGONFIRE81M
Status: offline
just wait till you hit the point when the boat starts to channel walk. mine will do it when im on glassy water when the nose stays down on a run . it scared the crap out of me the first time it done it and i almost lost control and wiped out
(in reply to headhunter23)
       Post #: 76
RE: The Unofficial all things Jet drive thread - 11/1/2007 1:37:10 PM
DRAGONFIRE81M
Status: offline
quicksilver hows the villain comeing? havent hard much in a while.
(in reply to DRAGONFIRE81M)
       Post #: 77
RE: The Unofficial all things Jet drive thread - 11/1/2007 3:59:38 PM
headhunter23
Status: offline
Channel walk? Is that where it's riding the aluminum?
Ivan.
       Post #: 78
RE: The Unofficial all things Jet drive thread - 11/1/2007 4:18:36 PM
Quicksilver1
Status: offline
I'm still alive, just got up .
As for the intake, I believe the drive should be flat on the bottom, you dont have to go crazy about getting it perfect, but that's what I do. Having the intake angle so the rear of the intake is higher than the front of the intake could give you more water at high speed. So in that case angling the grate would be ok.
The jet-villain is acting more like a parts box at the moment. horrible isnt it? The new surface drive villain is coming along nicely. I've patched up where I was going to put the jet, and in turn the transom and floor is very strong now. Only used fiberglass. Today if Steven is shipping at his normal speed, I should get all the parts I need today. It's fun having two project boats at the same time.
The jet-villain is getting the aluminum ripped out and all the fiberglass torn out(not easy). Havent wuite figued out what the bottom will be, probably ply wood(hobby sized)
_____________________________
Jet Villain IV (Graupner 29mm drive 700sc motor)
v(8.0) coming soon
       Post #: 79
RE: The Unofficial all things Jet drive thread - 11/1/2007 4:20:13 PM
Quicksilver1
Status: offline
quote:
ORIGINAL: DRAGONFIRE81M
oh boy does that happen to mine. Gets very unstable, only at WOT though. Never flipped it or anything.
v(8.0) coming soon
       Post #: 80
RE: The Unofficial all things Jet drive thread - 11/1/2007 5:45:07 PM
DRAGONFIRE81M
Status: offline
quote:
ORIGINAL: headhunter23
Ivan.
No its when your at a speed that the boat is just about riding on the top of the water almost like your seating in the middle of a sea sow
       Post #: 81
RE: The Unofficial all things Jet drive thread - 11/1/2007 7:27:09 PM
joccee
Status: offline
finally getting back to jetdrives again. Just ordered motor, esc and lipo for a graupner jet sprint. And I will probably get the boat and jet next week.
Mini Mogli GT, 540 9L 11.1v LiPo
Jet Sprint, 380 9XL 11.1v LiPo
       Post #: 82
RE: The Unofficial all things Jet drive thread - 11/1/2007 7:59:04 PM
Quicksilver1
Status: offline
Ivan.
I would even compare it more to driving a ski, not a big wide one, but more like a cross country snow ski.
btw I got my parts for my new villain(not a jet).......wheee stuff to build.
v(8.0) coming soon
       Post #: 83
RE: The Unofficial all things Jet drive thread - 11/2/2007 5:31:58 AM
headhunter23
Status: offline
Plates in and drying, will have boat back together and testing tomorrow afternoon.
Ivan.
Click to see fullsize image.
Click for fullsize
Click for fullsize
(in reply to Quicksilver1)
       Post #: 84
RE: The Unofficial all things Jet drive thread - 11/2/2007 2:31:50 PM
DRAGONFIRE81M
Status: offline
by the way i ordered a eflite Six-Series Brushless 2700 Kv Motor (28mm)
Key Features
Perfect match for 3D and aerobatic models weighing 28–35 oz (790–990 g) using a gearbox
Ideal for scale park flyers weighing 25–40 oz (710–1140 g) using a gearbox
Ideal direct drive motor in models 18–28 oz (510–800 g)
Ideal for models requiring up to 400 watts of power
Perfect upgrade for brushed 400 and 480 motors with same diameter and mounting hole pattern
High-torque, 6-pole slotted rotor design
Includes connectors, prop adapter and mounting hardware
High-quality construction with ball bearings and hardened steel 3.2mm shaft
Overview
Six-Series Brushless 6-pole motors are high torque motors suitable for either direct drive or geared or geared applications. They feature the same diameter and mounting hole pattern as brushed 400 and 480 motors so they make excellent upgrades for these classes of models. Six-Series motors are ideal for direct drive applications such as hotliners and other LMR products 18- to 28-ounces. They are also ideal for 3D and aerobatic models weighing 28- to 35-ounces, and for scale park flyers weighing 25- to 40-ounces, when using a gearbox. This is a perfect match for aerobatic and 3D models like the E-Flite Brio 10 (EFL2275) when using a gearbox, and pylon racers and hotliners when used direct drive.
Specs
Type: 6-Pole Inrunner
Size: 400 / 480 Upgrade
Bearings or Bushings: Ball Bearings
Recommended Prop Range: 5 x 4 to 6 x 5.5 direct drive or 10 x 6 to 12 x 6 with 2:1 to 3:1 gearbox
Voltage: 7.2 - 12
RPM/Volt (Kv): 2700
Resistance (Ri): .03 ohms
Idle Current (Io): 2.05A @ 10V
Continuous Current: 34A
Maximum Burst Current: 42A (15 sec)
Cells: 6-10 Ni-MH/Ni-Cd or 2-3S Li-Po
Speed Control: 35A - 45A Brushless
Weight: 80g (2.9 oz)
Overall Diameter: 28mm (1.10 in)
Shaft Diameter: 3.17mm (1/8 in)
Overall Length: 36mm (1.40 in)
wheelnut which motor would you use the e-flite or ammo 28-35-2700
Click for fullsize
Click for fullsize
       Post #: 85
RE: The Unofficial all things Jet drive thread - 11/2/2007 2:39:42 PM
Quicksilver1
Status: offline
I believe those are both 6-poled motors, which would make them compatible, in fact the eflight looks like the SV27 motor, but I could be wrong.
v(8.0) coming soon
       Post #: 86
RE: The Unofficial all things Jet drive thread - 11/2/2007 2:54:27 PM
DRAGONFIRE81M
Status: offline
compatible every where but $ the e-flite is 75 and the ammo is 39
       Post #: 87
RE: The Unofficial all things Jet drive thread - 11/2/2007 2:57:21 PM
DRAGONFIRE81M
Status: offline
quicksilver is align a good bl motor they come in the trec heil
       Post #: 88
RE: The Unofficial all things Jet drive thread - 11/2/2007 7:20:17 PM
LJH01
Status: offline
DF,
The Align motors are all right for the price, I have a BL430L (3550KV) that I tried in my Mini Sprint Jet and the KV was to high for 3S. The motor came out of a little pylon plane and I have quite a few flights on it with 3S pulling around 27 amps static. Becarefull what vintage motor you get, the old ones are known for losing the end bell, not a huge issue and you can reattach it using green loc-tite but still a PIA.
I will take some pictures of the Min Sprint over the weekend, it is functioning but I have not dressed it up yet.
Cheers,
Jim
