RE: The Unofficial all things Jet drive thread
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Boats >> Speed - Electric >> RE: The Unofficial all things Jet drive thread Page: <<   < prev  56 57 [58] 59 60 61 62 63 64 65   next >   >>
Login
RE: The Unofficial all things Jet drive thread - 7/20/2008 8:43:20 AM
fvega
Status: offline
Thank you for the information posted. As my next project will like to try a jet power boat. I am looking at the Dumas SK boats (either 27" or 36" with a flat bottom but only 3-4" on transom. Can I adapt a jet unit to such a boat? which unit would you recomend Graupner, KMB? what size unit? Help appreciated it. thanks
(in reply to Quicksilver1)
       Post #: 1426
RE: The Unofficial all things Jet drive thread - 7/20/2008 4:25:49 PM
DRAGONFIRE81M
Status: offline
welcome to the thread . i tock a look at those hulls im not sure how they well go with a jet drive but it looks like you have just enof room for the 29mm drive from grumpner . i would go with the 27" hull this drive will have plenty of power for it . im not sure if it would push the 36" to well but it does do a go job with a 31" i personly like the vee bottom sk hull its 19" if my nitro jet vee works out . i mite be building it with a .18 and the mini jet drive . here is some pic for every on the first is the 36" and the sec is the 19" that i like
Click to see fullsize image.
Click for fullsize
Click for fullsize
(in reply to fvega)
       Post #: 1427
RE: The Unofficial all things Jet drive thread - 7/20/2008 4:52:18 PM
fvega
Status: offline
Thanks for the advise, any thought about Grupner vs. KMB for jet drive unit?
(in reply to DRAGONFIRE81M)
       Post #: 1428
RE: The Unofficial all things Jet drive thread - 7/20/2008 4:54:50 PM
j.m.
Status: offline
graupner:
Cheap. less flow. Less thrust. Cheap.
KmB:
Expensive. Best of the Best. You pay for what you get.
_____________________________
!Signature your in it put, this read to time the took you If
If the World didn''t suck, then we would just fall off.
(in reply to fvega)
       Post #: 1429
RE: The Unofficial all things Jet drive thread - 7/20/2008 5:43:02 PM
Quicksilver
Status: offline
quote:
ORIGINAL: j.m.
graupner:
KmB:
lmfao! I hope no one actually takes that as advice
Game''s over, losers! I have all the money. Compare your lives to mine and then kill yourselves. -Bender
(in reply to j.m.)
       Post #: 1430
RE: The Unofficial all things Jet drive thread - 7/20/2008 5:53:22 PM
j.m.
Status: offline
why not?
(in reply to Quicksilver)
       Post #: 1431
RE: The Unofficial all things Jet drive thread - 7/20/2008 5:57:17 PM
DRAGONFIRE81M
Status: offline
they both have pros and cons . kmb is a great drive you do pay more then what you get motly in shipping . and you cant water cool like you can from the grumpner . the grumpner is a lot cheaper then the kmb. there more lighter dudy drive but you can water cool and the cost of shipping and the price of the drive is a lot less then the kmb . but quick should chime in since he has had both drive
< Message edited by DRAGONFIRE81M -- 7/20/2008 5:58:15 PM >
       Post #: 1432
RE: The Unofficial all things Jet drive thread - 7/20/2008 11:45:55 PM
Quicksilver
Status: offline
I just dont think KMB's are all that. I've explained my view on this several times(in this thread even), every time getting more condensed.
Really theyre both cheaply made, basically the same design and I just dont get how anyone can say there's a difference in thrust. Unless you've got something to back such a statement with, it's utter bs. The impellers are almost identical, other than the diameter.
The only thing I like about the KMB drives over the Graupner is the bearing on the motor side and the built in motor mount. However, when I'm throwing 16cells of power through a 700sc motor, I doubt that bearing does much.
I just did a cost comparison. If you live in the states, it will cost you roughly $123 US to get a 28mm KMB drive. A graupner unit(29mm) will run you just about half that $65. You could buy two graupner drives for the price of a KMB. Add to this the ability to replace a Graupner impelller and I cant see one valid reason to buy a KMB drive.....
I could go further but I've already said it before.
I feel the statement made earlier was unfounded and ignorant.
< Message edited by Quicksilver -- 7/20/2008 11:46:44 PM >
       Post #: 1433
RE: The Unofficial all things Jet drive thread - 7/20/2008 11:58:46 PM
DRAGONFIRE81M
Status: offline
one small thing about the impeller on the kmb you can replace it they sell them now. thanks for the oppenon on these drive quick
check out the bottom of the page http://www.jet-drive.de/cms/component/option,com_virtuemart/page,shop.browse/category_id,4/Itemid,17/
also i have gotten the nitro vee with a .26 ofna motor going just got done running two tanks on it . it still has the stock vee drive line in it but im going to run to hobby lobby to pick up a 29mm drive for it . qiuck if you still have your vee you mite wont to hang on to it .
Click for fullsize
Click for fullsize
< Message edited by DRAGONFIRE81M -- 7/21/2008 12:10:22 AM >
       Post #: 1434
RE: The Unofficial all things Jet drive thread - 7/21/2008 12:39:34 AM
j.m.
Status: offline
straight from a car, too.
       Post #: 1435
RE: The Unofficial all things Jet drive thread - 7/21/2008 1:06:28 AM
DRAGONFIRE81M
Status: offline
well yes it started life as a new ofna .26 that i put a GO water jacket on .
(in reply to j.m.)
       Post #: 1436
RE: The Unofficial all things Jet drive thread - 7/21/2008 1:11:56 AM
j.m.
Status: offline
i would suggest a new pipe for more top end.
like this:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXZ558&P=7
       Post #: 1437
RE: The Unofficial all things Jet drive thread - 7/21/2008 1:16:59 AM
DRAGONFIRE81M
Status: offline
sorry im not posting to fell update on here till it gets the jet drive . the fell post is on the nitro forum under the nitro vee . im only useing this pipe to brake in the motor . i have a mac 3.5 pipe on the way just didnt wont to wait on it .
(in reply to j.m.)
       Post #: 1438
RE: The Unofficial all things Jet drive thread - 7/21/2008 4:45:26 AM
Quicksilver
Status: offline
quote:
ORIGINAL: DRAGONFIRE81M
touche! you've got me there
Yeah I'm not selling the nitro vee, all my boats are in dry dock right now. This car thing this summer is killin me. However I finally scored a vehicle, for some reason my avatar has not changed yet. Got an Acura CL
< Message edited by Quicksilver -- 7/21/2008 4:46:05 AM >
       Post #: 1439
RE: The Unofficial all things Jet drive thread - 7/21/2008 11:12:06 AM
