rcav8or
Joined: 12/15/2001 From: Oxford, IN, USA Status: offline
The Li-ion batteries do not develop a "memory", as some Ni-cad's are/were prone to do. Therefore, cycling is not necessary. However, if you feel the need to cycle, it should be only if you feel there is a) something wrong with the pack, or b) if it is getting towards the end of it's useful life. This being said, the Li-ion packs [COLOR=red]WILL BE DAMAGED[/COLOR] by allowing voltage to drop below 5.5 volts. Every charge/discharge charger I have seen, allows voltage to drop way below this, for the Ni-cad packs, even as low as 4.4 volts, which will damage a Li-ion pack. There MAY be charger/dischargers out there, that allow you to set the minimum voltage that the battery will be discharged to, but I haven't seen any. I have been doing tests on both the Powerflite, and Duralite Plus batteries, for an upcoming review for the RCU Magazine. I have put 6 batteries through multiple discharge and charge cycles, to test them. The review will go in to a lot more detail, but my findings have been that they are very consistent, in their discharge rate, with a constant 1 amp load. I have put them in series with an 8 ohm, 50 watt resistor, and had a monitoring meter on them, to graph the results. Great care has to be taken, as I have found that they maintain a constant, SLOWLY decending voltage until just over 6 volts. Then the fall is very rapid, with perhaps a minute or two, before they are down to "critical voltage" of 5.8 or so. If you want to cycle one, you must be prepared to monitor the battery VERY closely, that it doesn't drop below about 6 volts. Just as we have learned to deal with Ni-cads, and Ni-MH's, and their idiosyncrosies, we will learn to deal with Li-ion, as they very well may be the batteries of the future. I believe the way to use the Li-ions, is to monitor them before flights, and quit flying when voltage (before the regulator!) reaches about 6.9 volts, under a load as defined by the company in their instructions . But you'll find a very steady voltage up until that time.... Look for the upcoming review... Rog, the Mod
_____________________________
Roger Phillips AMA #387890
