Old Man Mike
Joined: 4/21/2007 From: Huntertown, IN, USA Status: offline
quote:
ORIGINAL: jesolins Mike, Can you please help me understand the requirements for the large/small frame Brushless DF FCB? I understand the dimensions as a requirement, but I was wondering how different gross weights would be considered in the different versions? I am guessing here a bit, but I presume the calibration difference between the large/small DF FCB has to do with the weight differences too. So if I got the large frame calibrated DF FCB and mounted it on a less than 33cm arm length (small) frame, would that mean I could carry a larger payload with more stability on the smaller frame? You mentioned in an earlier post that this combination, which I presume is in a standard weight configuation, would occillate a bit, but how much? To the point of loss of control, or just enough to be "jittery", sort of like when the TI gets a bit out of whack? Conversely, would that make the small frame calibrated DF FCB mounted on a small frame more of a "sport flyer"? Thanks, Jim quote:
ORIGINAL: Old Man Mike Dammar now has a special webpage for the brushless PWB: Brushless Controller Board The small frame is for the original DF with motors spaced approximately 230 mm from the center. The large frame is for platforms with motors spaced approximately 330 mm from the center such as discribed in this thread: 1000mm Custom Quad Copter Mike Jim, It really does not matter much what weight you are carrying with the small frame, it is better to have the small frame PWB version instead of the large frame PWB version. That said, you can probably fly either frame size with either version of the PWB but it would not be optimum. Here is what you can expect if you mix things up: 1) Flying Small frame with Large frame PWB - tendency to oscillate 2) Flying Large frame with Small frame PWB - overly sensitive to operator controls and oscillation in TI at take-off. That has been my experience with the limited testing done with a mismatch between the frame and pwb version. Mike
