DanSavage
CA, USA Status: offline
quote:
ORIGINAL: KitBuilder Has anyone built the VK Nieuport 17 or Camel kits and is there anything that should be noted? I'm trying to decide which one and am leaning toward the 17 b/c most do the Camel or Pup. Look like real nice kits for 225 beans shipped. Mike Hi Mike, I built the Proctor VK Nieuport 17 several years ago. Really nice kit. Clean die-cutting, generous hardware package and detailed plans. The model flew great. Once in the air, it was smooth, stable and manueverable. It looked best flying just at tree-top level where you could see and appreciate the scale details. There were a couple of things I didn't like about the design. 1) External wire bracing. All of the flying surfaces are externally braced using flying wires. Without really thickening the wing(s) to make them cantilevered, there's no way around this problem. 2) Flimsy landing gear wires. The kit is set up to use fairly small diameter wire for the core of the landing gear struts. The problem I had was that when the model ground-looped, the tires on the Williams Bros. wheels would lay over allowing the wheel itself to come in contact with the ground. When it did this it would dig in, causing the model to 'hop' and 'skip' across the ground breaking the LG brace wires. I eventually used 90# SS fishing leader and stopped breaking wires. A better solution would've been to use heavier wire for the cores so they wouldn't need to be externally braced. One other point. Because the nose moment is so short, make sure to put all, and I mean ALL of your radio components in front of the cockpit. Even then, you'll need to put the receiver pack in front of the firewall and even then, it will still need lead to balance it. Other than these minor points, the model is a great design and I wouldn't hesitate to recommend it to anyone. Dan
< Message edited by DanSavage -- 10/29/2007 4:57:28 PM >
