jose_ribeiro
Joined: 1/10/2005 From: campo grandemato grossodo sul, BRAZIL Status: offline
For all you guys searching a good engine 25% combination, i highly recomend the evolution 26gt2 in the all 25% airplanes peakmodel sells, matched to a 18x6 wood or a 17x8 apc prop this engine is very good in that models. For those who want to save money, the best option is the peak 26 + extra 260 25%, if you not have time or do not like mesing with engines , i sugest the os 120AX engine, or spend some more and get the 26gt2 gas. The yak 25% and edge 25% i think are capable of handling the SPe40 engine, they are the bigest and strongst structure. Always keep in mind to make light setups, 1 elevator servo (when possible), 1 ruder servo, nimh packs not oversized. This are very nice airplanes, but you should setup it light to enjoy the most out of. Jose.
