Turbo Jett pressure tap
Tower Hobbies
Logged in as Guest
  Printable Version
O.S. Engines O.S. BGX-1 3500 w/ BCM #4224 Pitt
Seller:  jmhernan
Details:   $200.00   |  10/2/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> Jett Engineering Support >> Turbo Jett pressure tap
Page: [1]
Login
Turbo Jett pressure tap - 10/27/2007 2:16:26 AM
neversink
Status: offline
Hi Bob,
I fished a Turbo Jett out to mount (long after any instructions were misplaced) and noticed the lack of a pressure tap. Any suggested locations to drill and mount one? Thanks again!
Rich
       Post #: 1
RE: Turbo Jett pressure tap - 10/27/2007 3:15:06 AM
bob27s
Status: offline
Hi Rich......
All of the turbo jett muffler should have a pre-installed pressure tap on them when they ship.
Which size do you have ? I can try to get the correct location for you.
Bob
_____________________________
Bob Brassell
Jett Engineering - Engine Mfg Support Forum Host
(in reply to neversink)
       Post #: 2
RE: Turbo Jett pressure tap - 10/27/2007 2:15:14 PM
neversink
Status: offline
Bob, it's a 6.5 cc (.40-.60) size. I did find the shipping invoice from 2000....about time I hooked it up!
Rich
(in reply to bob27s)
       Post #: 3
RE: Turbo Jett pressure tap - 10/29/2007 5:14:44 PM
bob27s
Status: offline
OK.....
location can be anywhere on the back face... (flat surface). Closest to the engine possible. Usually just "aft" of the engine adapter/header works fairly well.
Bob
btw... what engine are you using this on ?
Bob
Bob Brassell
       Post #: 4
RE: Turbo Jett pressure tap - 10/29/2007 11:01:42 PM
neversink
Status: offline
Thanks Bob,
The muffler is going on a sport jett .46 and then in a Hangar 9 Aresti. So I'm drilling at the yellow arrow in the attached image. Thanks again!
Rich
Click to see fullsize image.
Click for fullsize
       Post #: 5
RE: Turbo Jett pressure tap - 10/30/2007 5:52:00 PM
bob27s
Status: offline
yep, that is about the right place.....
Be sure and post a few photos when you have the plane all together!
The photos here are that same engine/muffler combination in my P-51
Turns the crud out of a 10x6, likes big props fairly well too 11x4, 11x5. Good trade of rpm for torque.
I fly the P-51 with a 12x4 ---- trying to slow it down a bit Ground peak is right at 14K rpm, and I fly it set around 13,400
Also runs nice with the 12.23x3.75 prop.
In your aresti, start out with the lighter props..... work up.
Click for fullsize
Click for fullsize
Click for fullsize
Bob Brassell
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.438RCU1
