Hornet won't hover straight - drifting
Tower Hobbies
Logged in as Guest
  Printable Version
MS Composit Hornet X-CP ARF w/Brushless Motor
Seller:  Erick Royer
Details:   $100.00   |  9/6/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Helicopters >> Electric RC Helis >> Hornet won't hover straight - drifting
Page: [1]
Login
Hornet won't hover straight - drifting - 3/28/2003 5:46:15 PM
Pylanton
Status: offline
I just set up my new hornet and took it out for a test flight. Whenever i punch the throttle, it gets off the ground but before it does, it always drifts either left to right or forward and back (just when it's barely off the ground)! I don't think it's the tail rotor, that seems ok. I've tried to just trim it out to counteract the drifting - that works but then when it gets into the air, it always seems to want to go in the direction i trimmed it (It moves at a nice clip too!) Any suggestions??
_____________________________
Prezident Ruskoy Mafii V Americe!!
       Post #: 1
Drifting - 3/28/2003 7:54:43 PM
tp777fo
Status: offline
Having the same problem with mine but an getting closer. I have the subtrim menu displayed on my JR 8103. Am making very small adjustments to get the probmen fixed. If you are outside any wind will cause this very light heli to drift also. Get it high enough to get out of ground effect and the hover will be much more stable.
Tom Perry
Check six!
(in reply to Pylanton)
       Post #: 2
Hornet won't hover straight - drifting - 3/29/2003 12:33:16 AM
Thrustline
Status: offline
The drift is normal on before it lifts off, you can't trim for it. That is why once in the air it changes where it is actually trimmed to. With a litle practice you can compensate for the drift if you watch closely with slight stick corrections or as some say just point it to the right for take off, but as you get better you will not notice the drift as it builds the cushion of air it takes off from.
       Post #: 3
Hornet won't hover straight - drifting - 3/29/2003 3:31:32 AM
Pylanton
Status: offline
Thanks for the info guys. I did notice that it gets a lot more stable when it's up min the air. The drift does make it hard to hover at home though!!
       Post #: 4
Hornet won't hover straight - drifting - 3/29/2003 4:05:57 AM
Thrustline
Status: offline
You can trim for the movement in the air and it should stop it from moving around, just not the slight drift on the ground. You will get movement if you stay close to objects from the rotor blast on these little guys, but not anything drastic. Make sure the servos are solidly mounted, you can secure them with a tie wrap too. Check the blade balance too on the paddles and main, if slightly off will work abit against you.
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.891RCU1
