Anyone Made a Foam Cutting Tool?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> S.P.A.D. Aircraft - Coroplast design >> Anyone Made a Foam Cutting Tool?
Page: [1]
Login
Anyone Made a Foam Cutting Tool? - 10/27/2007 5:55:53 AM
huck1199
Status: offline
I am building a foam (blucore) plane from scratch and find it is hard for me to cut the 1/4" foam with accurate 90 degree edges. That is, I tend to lean the model knife when going arround curves. This is a problem when joining pieces because there are gaps on one side of the joint because the cuts are not square. I am try to design some sort of tool that will hold an exacto blade perpendicular to the foam surface. It must be small enough to let the user see the line to be cut, but large enough to provide stability.
Anyone crafted such a tool? I was thinking that a wood block about 1" wide, 2" long, and sloped hieght 1/4" to 1". with a slot cut to hold the blade and a pair of blind nuts aon each end with machine thumb srcews to secure the blade. The use could drae this over the foam piece and cut square edges with ease. Any thoughts or designs would be appreciated.
Thanks Huck
       Post #: 1
RE: Anyone Made a Foam Cutting Tool? - 10/27/2007 6:20:33 AM
kbear
Status: offline
Sounds like a plan to me. simple and effective. I say go for it.
(in reply to huck1199)
       Post #: 2
RE: Anyone Made a Foam Cutting Tool? - 10/27/2007 1:37:23 PM
DavidAgar
Status: offline
Here is a stripper that kinda sounds like what you are proposing, I think.
http://www.masterairscrew.com/index.asp?PageAction=VIEWPROD&ProdID=20
Good Luck, Dave
_____________________________
If the screw ain't loose then things ain't normal.
Dave Agar
AMA#97144
(in reply to kbear)
       Post #: 3
RE: Anyone Made a Foam Cutting Tool? - 10/27/2007 5:43:18 PM
spad4mebaby
Status: offline
That Looks About Right. Make a TLAR version of that tool.
or do what Tatoo used to do
Very Carefully Very Carefully embed a blade in a wooden work surface.
Use this blade like a circular saw blade to cut curves.
Use a center pivot (a nail) to help cut perfect circles. Wear gloves! Well almost perfect.
I am currently trying to build a Geobat from the flat foam forum.
Using bluecor and 4MM coro.
(in reply to DavidAgar)
       Post #: 4
RE: Anyone Made a Foam Cutting Tool? - 10/28/2007 5:40:03 AM
huck1199
Status: offline
Dave
Yes that is what I need except the blade would be turned 90 degrees. I have looked arround quite a bit for a tool; never thought of a stripper! Although the stripper tool may provide better visibility to follow the line of cut.
Thanks for the tip Huck
       Post #: 5
RE: Anyone Made a Foam Cutting Tool? - 11/24/2007 1:57:44 AM
PatternPilot
Status: offline
yep I use my CNC router machine for cutting foamies..
scott anderson
Team PMA rcfoamy.com
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.469RCU1
