Discharging Batteries - Need Help
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> Common Sense RC Support >> Discharging Batteries - Need Help
Page: [1]
Login
Discharging Batteries - Need Help - 10/28/2007 4:01:02 AM
fscott729
Status: offline
I have a pack of new nicads that were once charged but never used. The have been in a box for about 3 or 4 years. I heard that I should first try to discharge them and then recycle them about 5 times. I have a triton charger and will give that a try. I need to verify the correct discharge rate. This is a pack of 8 cells rated at 1700mah. They have cp-1700SCR on the side . I think they are considered a sub C battery made by Sanyo. I figure when I charge them I will do it at the .1c rate of 170ma. Can anyone tell me the best discharge rate? I know the cut off discharge voltage should be 7.2volts.
Thanks....franko
< Message edited by fscott729 -- 10/28/2007 5:01:25 AM >
       Post #: 1
RE: Discharging Batteries - Need Help - 10/28/2007 11:21:25 PM
mrasmm
Status: offline
yeah, 7.2 to 8.0v for the discharge voltage. The packs may be toast though because of how long they've been sitting. You'll want to make sure they cycle really close to 1700mAh, if they are less than about 1400mAh on your test, it's probably best to just replace them.
It sounds like you've got a good base on all of the info. To get specs mfg's often to a c/10 to a c/15 discharge rate. It's best to compare them to your own eq, like a base test right when you get the packs. Basically on your discharge you probably want to go slower than a 1C discharge, and as slow as a c/10 discharge rate, and just see where your packs end up. Do this about 5 times like you already said, and the capacity should keep climbing. If it gets above 1400mAh, then you should be good to go, and if not, I would just replace them. Batteries are alot cheaper than a downed RC (unless it's a car, then just use the heck out of 'em until they are completely dead).
GL and frrel free to ask q's
_____________________________
I don't always check every thread I respond to, so feel free to PM me
(in reply to fscott729)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.563RCU1
