MMatheny
TX, USA Status: offline
quote:
quote: ORIGINAL: MMatheny You cannot swap between high and low band on the receiver. Sorry ....wrong. High band low band only applies to Futaba brand recievers, and then, only those labeled that way. All you need to do is get a reciever crystal for the helimax reciever on the channel you need. Whether or not it uses a negative shift reciever or not, which is what you need to be compatible with your Futaba transmitter I dont know but I think it is. You CAN swap RX channels IN one band or the other, not between bands (high/low) - you can only swap TX channels on the synthesized TXs - legally. Wrong again. For the reasons I stated above. Also you can swap the channel on module based transmitters by changing the entire RF module, NOT by swapping crystals such as the 7c or the crystal inside the rf module. Well, I'll have to just believe you on the first statement - on the second, he mentioned a 7CH, which DOESN'T have modules, and you can't AMA LEGALLY swap xtals on it, but you're correct if it uses modules you can put any channel in it you can afford (the modules are quite a bit more expensive than a xtal!!) I have read several times that the RX is based on a Futaba design. (not directly from HeliMax though!)
_____________________________
Mike "Never use your shins as a blade tracking device" - Mike
