shizack
Joined: 2/18/2007 From: Augusta30909, USA Status: offline
Keep those CP birds in the nest (or use them as RADD's trainers) until you're comfortable doing circuits and hovering in all orientations with the FP. A coax has a natural tendency to "auto-level" itself. Not so with a sigle-rotor heli. The FP has some lift built into the blades, and is easier to level than a CP. The CPs will "slide" into the ground quickly if you don't have good recovery skills. This is one place (of many) that a sim shows it's value. If you have a sim, practice heavily on the same type circuit you're trying to fly. If you don't have one, just take it slow. It'll come to you. Keep in mind that with a single-rotor, you pretty much have to command it into any position it needs to be. For example, making a CCW circle, as it turns left and comes back toward you, you usually have to give a little right cyclic to bring it back upright. Always FLY THE NOSE. Don't look at the patterns your tracking tape makes while the rotors spin, and don't admire the pretty decals on the canopy. Use the sticks to keep that nose pointed in the direction it needs to go. I find myself flying erratically now and then, and it's almost always because I'm losing focus and flying the tail or even flying the skids. Will it hover hands-free at all? Any halfway-decently set up heli will hover hands-free for at least a second or two. It'll wander a bit, but it shouldn't dive aggressively in any direction. Drill yourself on getting back to tail-in instantly as soon as thing start to look hairy. Don't try to fly out of trouble unless you have to. Check the CG and make sure the swash is level. If all is well in this department, try again and let us know how it goes.
