A123 Racing
Joined: 8/25/2006 From: Hopkinton, MA, USA Status: offline
Hey, We did a Losi Eight electric conversion for the I-Hobby show we recently attended. It was running a 6S1P (19.8V 2300mAh) pack, with a Steve Neu 1515/1Y motor powered by a CC Mamba Max (Pushed to its limits, but performs awesome). It has not been radar tested but is estimated to be in the upper 40's to low 50's miles per hour, and the handling is phenomenal. The pack weighs roughly 16oz, runs the car for ~10 minutes, and charges in 15 minutes. The pack can be charged 1000 times, and does not risk damage if you crash. Compared to a LiPo 2200mAh which weighs roughly 13 oz. Run time will be lower not only due to less mAh but also because of unusable energy due to the required cut off voltage. Hope this helps. Power . Safety . Life Brian
