jim pettis
NY, USA Status: offline
Finally got mine in the air today. 35 degrees. Battery did in fact only last 2 mins. 38 seconds. Focus was HORRIBLE. Ended up opening the case, opening the lens cover, and after a bit of surgery, freeing up the lens so I could test different focus points. I made a scratch on the side of the lens mount, and the lens face. Best I came up with was a little less than 1/8 of a turn in. Stupid me didn't save the test pics to show that there can be a huge change in the sharpness of the pics and videos....sorry. One thing however....the ribbon that connects the lens unit to the main unit can, and WILL pull out of the main unit. There is a tiny black clip that secures it in place. You have to gently remover that clip (I say gently, because the infrared sensor blocks one side, and I ended up breaking one of the tabs off), slide the ribbon back into the slot, and then reclip the black tab on top of it. Thought I had ruined it when it happened, but the fix worked, and it still works, but with much better clarity.
_____________________________
Work is for people who don't know how to fly....
