how to configure A123 set up
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> A123Racing Support >> how to configure A123 set up
Page: [1]
Login
how to configure A123 set up - 10/31/2007 4:49:02 PM
incarus
Status: offline
Ok I am going to try my hand at my first electric using A123 set up thanks to the help here.
I will be using a 12s2p set up to a eflite Power 160 with a Castle HV85. I will be using a jr 9 channel pcm reciever. with some Hitec/FMA high torque servos(non digitial).
my question is am I configuring everything like I would a standard lipo set up. ie motor to esc which inturn plugs into reciver which has the servos pluged in to the respective channels?
the reason I am asking this is I am reading things about regulators???? do I need seperate bat packs for the reciever?
will the reciever handle the power as well as the servos?
I dont want to burn anything up
if some one has a diagram etc to bring it into prespective i would apreciate it
       Post #: 1
RE: how to configure A123 set up - 11/2/2007 2:39:02 AM
everydayflyer
Status: offline
It concerns me when someone choses such a large electric for a first .
You will need to either use a seperate BEC ( UBEC) or a seperaste receiver / servo battery.
Many use a 2S A123 battery for the rec./ servos in larger aircraft.
The BEC built into most ESCs can only be used with up to 3 Micro servos and not with over 3S LiPoly.
Many high cell count / high amp. ESCs do not even have a built in BEC at all.
Charles
(in reply to incarus)
       Post #: 2
RE: how to configure A123 set up - 11/2/2007 9:25:52 PM
incarus
Status: offline
I have a cap 231 at home that has been sitting on the shelf so I though I would put it to use. You are correct the Hv85 from castle does not have a BEC so I will have a pack for the receiver....probably better off any way just in case. I can always nurse her back to the runway if my bat pack on the motor gives up
since were are on the subject if I do configure this aircraft how much wing area should I have to support a 12 cell A123to get some decent perfrmance ie mild 3d,acro etc
(in reply to everydayflyer)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.234RCU1
