WarbirdAirRacer
Joined: 12/18/2002 From: Littleton, CO, USA Status: offline
I am still working on the manual as we speak, It takes great time. As for a pre order special that will be posted on the website in due time. We are working on alot of changes to the website and some other up coming things and it all takes a great deal of time. But please keep checking back for more updates. Thanks John P.S It will come just like our other ARFs with the fallowing * High performance ARF/ FA = FAST ASSEMBLY * Ultra light weight High performance model * First ARF to feature foam sheeted bottom, No stringers. * Pre hinged wings and stabs with Robart hinges. No gluing required * Super light super strong weight Composite wood and foam fuselage * Pre hinged Fin and Rudder. * Pre mounted landing gear * Pre mounted wheel pants * Pre mounted main gear cuffs * Pre mounted cowl with cowl ring. No exterior screws exposed. * Anodized T-6061 aluminum tubes * Pre installed dash panel * Canopy is pre mounted and painted. Pre painted cock pit * Removable wings and stabs * 1 ¼” ball bearing servo arms * Ball bearing control horns * Pre installed and covered engine box for detailed engine compartment * Detailed and painted brake covers for wheel pants * Complete hardware included * Fuselage is set up for pipe installation * Two stage polyurethane coatings on all fiberglass parts * Pre drilled control horns * Control horns included * Laser cut engine mounting templates * Interlocking firewall and landing gear plate for improved strength
< Message edited by WarbirdAirRacer -- 11/1/2007 1:30:08 AM >
_____________________________
Tat-Tude 379
