Top Flite Corsair
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Crash & Rebuild >> Top Flite Corsair
Page: [1] 2   next >   >>
Login
Top Flite Corsair - 11/1/2007 6:42:31 PM
andernamen
Status: offline
Two previous attempts to fly this plane ended with the plane flipping over onto the tail while taxiing at full speed (trying to take off). My attempt to correct this was to add elevator while taxiing......BAD idea on a Warbird!! She leaped up almost vertically and rolled immediately to the left before smashing into the ground nose first. Live and learn. She was badly mauled and I should have no business trying to rebuild her....but what the hey! I rebuilt a TF P-40 after a dead stick and high speed stall straight into the ground. Still flies okay. The corsair was crashed and fixed before by someone else, and this has really made the rebuild challenging. At least I can see the light at the end of the tunnel!
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by andernamen -- 11/1/2007 10:18:05 PM >
       Post #: 1
RE: Top Flite Corsair - 11/1/2007 6:54:49 PM
Edwin
Status: offline
I think we all go thru this at some point. Just like driving a clutch. Just use the elelvator to balance it while rolling. I find I have more trouble with this when I switch from easy flying sport planes back to warbirds. Takes a few times to remember.
Edwin
(in reply to andernamen)
       Post #: 2
RE: Top Flite Corsair - 11/1/2007 8:16:07 PM
bassfisher
Status: offline
Sounds to me that throttle management is needed on the ground! Anytime that I moving my taildraggers (all my warbirds included) under their own power, I always hold hold full up elevator. On some of my planes, I have to hold hi-rate up elevator to keep the tail on the ground during a fast taxi. You might want to increase the size of the mains or bend them forward a little to help taxing. Hopefully your rebuild goes well.
_____________________________
It only takes two things to make an airplane fly -- AIRSPEED AND MONEY
(in reply to Edwin)
       Post #: 3
RE: Top Flite Corsair - 11/1/2007 8:45:22 PM
mboland
Status: offline
The trick is in releasing Up elevator at the right time and amount during your take off roll.
As Edwin pointed out, very similar to learning to use a clutch properly.
What I use:
Taxi and position for take off using full up.
Start the take off roll with full up for no more than the first few feet
By the time the plane reach's half take off speed you should have neutral elevator and the tail should be raised off the ground
Use elevator to control nose attitude for a normal take off.
It's getting the timing right of when and how much to release the elevator that takes the practise.
It's the quality of life that counts, not the quantity.
(in reply to bassfisher)
       Post #: 4
RE: Top Flite Corsair - 11/1/2007 9:54:24 PM
Dr1Driver
Status: offline
And why are you taxiing at full speed? The ONLY time you need full speed on the ground is on takeoff.
Dr.1
There's a Hun in the sun!
(in reply to mboland)
       Post #: 5
RE: Top Flite Corsair - 11/1/2007 10:09:01 PM
andernamen
Status: offline
Actually, attempting to take off would be more accurate than taxiing. I'm just so worried about having enough speed to avoid tip stall that I like a long take off run. While making the long take off run is when I kept flipping over.
< Message edited by andernamen -- 11/1/2007 10:15:36 PM >
(in reply to Dr1Driver)
       Post #: 6
RE: Top Flite Corsair - 11/1/2007 10:21:19 PM
Edwin
Status: offline
Then its mostly a balancing problem. By all means keep it on the ground until you have enough speed. I always like a little more to make sure it DOESNT tip stall. Whatever you do, dont firewall the throttle to take off. Sounds like you just need practice. I added weight to a Super Sportster 60 to practice long take off rolls. Not quite the same, but helped a little.
Edwin
       Post #: 7
RE: Top Flite Corsair - 11/2/2007 3:30:42 PM
Flak
Status: offline
F4U Corsairs tend to LEAP into the air if not managed properly on take off. Place the elevator on LOW RATE for a nice take off. Good luck.
"Keep Em Flying!"
Flak
(in reply to Edwin)
       Post #: 8
RE: Top Flite Corsair - 11/3/2007 1:49:36 AM
Edwin
Status: offline
I like to setup my corsairs with minimal elevator throw, All the rudder I can get, and ailerons setup by the recommendations in the manual. All of the corsairs I've flown were real pitch sensitive. It wouldnt be a bad idea to setup hi/lo rates on all your flight controls and start off with hi rates on ailerons and rudder, and low rates on elevator. This is generally true for all of my warbirds come to think of it.
Edwin
(in reply to Flak)
       Post #: 9
RE: Top Flite Corsair - 11/27/2007 2:43:23 PM
andernamen
Status: offline
Some "slow going" progress
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to Edwin)
       Post #: 10
RE: Top Flite Corsair - 11/27/2007 5:34:45 PM
Huntster
Status: offline
Are you flying on the taxiway at Fentress or out on the grass strips in Chesapeake? maybe your runway is giving you issues. Low rates would be a nice thing to use so you don't over input.
       Post #: 11
RE: Top Flite Corsair - 11/27/2007 7:42:35 PM
johnny bubba
Status: offline
Repairs looking good. Ever consider using a catapult on take off? LOL j/k.
(in reply to Huntster)
       Post #: 12
RE: Top Flite Corsair - 11/27/2007 9:06:38 PM
andernamen
Status: offline
I've flown this plane at Fentress, but prefer grass due to my crappy landings. Asphalt is hard on cowlings and props. My club has a nice grass field. I wish I could say it was the field's fault, but have to chalk this one up to my own inexperience. I'm using low rates for take-off's, but I've discovered on warbirds, they don't really need much elevator. I had the stick back only slightly when she went vertical.
(in reply to johnny bubba)
       Post #: 13
RE: Top Flite Corsair - 12/7/2007 12:27:42 PM
kid chuckles
Status: offline
My Sundowner is balanced correctly and flys great. (well the two times i flew it) but it also wants to pivot over onto the nose. It is very light in the rear. I have to hold full elev. Taxiing around. Once you get it to half throttle it is better but if you were to hit just a small snag on the grass field I fly off of it noses over QUICK. So when it lands you also have to get it down and then back on the elev. to keep it from nosing over. Scares me bad. That is why in almost a yr. of having it it has flown twice. I am a scardy cat meooooooooow.
       Post #: 14
RE: Top Flite Corsair - 12/11/2007 4:34:20 PM
andernamen
Status: offline
The firewall is on and the wing saddle is finally done. At first the wing saddles were not level (twisted) and caused the wings to be out of alignment with the elevators. I had to do some shimming to get it right. It was a pain, but in the end, I'm happy with the result. I re-sheeted portions of the top and bottom of the wing. Now the only thing left to do is the covering and putting the engine on. I stole the engine from the corsair and put it in my P-40 (Saito 1.20), so now th4e corsair will have a Super Tigre .90. I don't plan to re-cover the whole airplane, just the damaged portions. It won't look that great, but this is going to be flyer, not a beauty "hangar" queen.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to kid chuckles)
       Post #: 15
RE: Top Flite Corsair - 12/11/2007 4:42:18 PM
