RE: What is the cheap and best A123 charger & A123 balancer?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> A123Racing Support >> RE: What is the cheap and best A123 charger & A123 balancer?
Page: <<   < prev  1 [2]
Login
RE: What is the cheap and best A123 charger & A123 bal... - 2/18/2008 8:51:10 PM
everydayflyer
Status: offline
http://www.rcuniverse.com/forum/m_6477096/tm.htm
Only practical for groups of 3S however you could charge two ea. 3S packs in parallel and use them in series as a 6S.
Charles
(in reply to maR/Co)
       Post #: 26
RE: What is the cheap and best A123 charger & A123 bal... - 2/18/2008 9:06:55 PM
hakank
Status: offline
Charles. How many amps are you charging with in the beginning of the cycle following your link?
/HÃ¥kan
(in reply to everydayflyer)
       Post #: 27
RE: What is the cheap and best A123 charger & A123 ba... - 2/18/2008 10:17:43 PM
everydayflyer
Status: offline
That depends on the resistence (wire GA and length) the discharged voltage of the A123 pack and the voltage of the source (deep cycles).
Early on I was using around 8 feet of approx. 17 GA and from memory starting amps. with 3S at 9.6V and deep cycles at approx. 12.2 (under load) charge rate was around 25 amps. I have gone to 5 1/2 feet of 16 GA and with same conditions starting amps. close to 30.
There are plenty of specs. in the Thread at RC Groups.
Charles
(in reply to hakank)
       Post #: 28
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.281RCU1
