everydayflyer -> RE: What is the cheap and best A123 charger & A123 balancer? (2/18/2008 10:17:43 PM)
That depends on the resistence (wire GA and length) the discharged voltage of the A123 pack and the voltage of the source (deep cycles). Early on I was using around 8 feet of approx. 17 GA and from memory starting amps. with 3S at 9.6V and deep cycles at approx. 12.2 (under load) charge rate was around 25 amps. I have gone to 5 1/2 feet of 16 GA and with same conditions starting amps. close to 30. There are plenty of specs. in the Thread at RC Groups. Charles
