81's round servo horn    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> 81's round servo horn
Page: [1]
Login
81's round servo horn - 11/3/2007 1:50 PM
DBono99
Score: 100
Last Login: 2/26/2013
Status: offline
Hi I'm going to use the round servo horns..Now the 3 holes on side of the horn, which one will give me more travel..
Thanks Dan
Hide Signatures
       Post #: 1
RE: 81's round servo horn - 11/5/2007 7:32 PM
onewasp
Score: 115
Last Login: 4/15/2013
Status: offline
< Message edited by onewasp -- 11/5/2007 7:43 PM >
_____________________________
The ground reached up and smote my airplane
Hide Signatures
(in reply to DBono99)
       Post #: 2
RE: 81's round servo horn - 11/5/2007 10:18 PM
DBono99
Score: 100
Status: offline
Hi Where is ALL the Hitec help??? Maybe I should switch to Futaba??
Dan
Hide Signatures
(in reply to onewasp)
       Post #: 3
RE: 81's round servo horn - 11/5/2007 11:12 PM
A.T.
Score: 181
Last Login: 5/22/2013
Status: offline
quote:
ORIGINAL: DBono99 Hi Where is ALL the Hitec help??? Maybe I should switch to Futaba?? Dan
quote:
ORIGINAL: DBono99 Hi I'm going to use the round servo horns..Now the 3 holes on side of the horn, which one will give me more travel..
1. Hitec USA is open Monday - Friday, your question was asked on a Sautrday..
2. Not enough information - are you wanting equal travel on both sides of the servo operation or more travel on just one side? A mechanical set up depends upon what you are trying to achieve and also upon the angle of the actuating arm/horn of the throttle, aileron, elevator or rudder etc. Is it at right angle to the control surface or angled forwards or backwards for differential?
Why not simply plug the servo into your receiver and use a ruler, held along side, (or mark movements on a piece of card) to find best position for your required set up?
Further information is available under sub sections "Aircraft Design. Airfoils, Pull-Pull Systems, Flight Trim & Static Thrust Calculator" and "FAQ = Answers for Beginners and Advanced RC'ers" on my web page.
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
R/C hobby consultant for various companies
Hide Signatures
       Post #: 4
RE: 81's round servo horn - 11/6/2007 1:16 AM
DBono99
Score: 100
Status: offline
Hi Alan What would be ideal is to have 3/8 up and 1/4 down on the ailerons..I'm only using a single servo in the wing, so I'n not sure IF that set up is possible..
THanks Dan
PS It's now 5pm on the East coast..Hitec has been open for awhile..
Hide Signatures
(in reply to A.T.)
       Post #: 5
RE: 81's round servo horn - 11/6/2007 4:38 AM
A.T.
Score: 181
Status: offline
quote:
ORIGINAL: DBono99 Hi Alan What would be ideal is to have 3/8 up and 1/4 down on the ailerons..I'm only using a single servo in the wing, so I'n not sure IF that set up is possible..
THanks Dan PS It's now 5pm on the East coast..Hitec has been open for awhile..
Sorry, without knowing the length of the aileron horns and rake thereof, I could not even hazard a guess. Suggest you refer to Differential Aileron Throw by Clay Ramskill which has some good diagrams to answer your questions. The rest of Clay's technical articles and diagrams are also very well worth the time taken to read/view them.
Regards
Alan T.
Hide Signatures
       Post #: 6
RE: 81's round servo horn - 11/6/2007 10:14 PM
MikeMayberry
Score: 104
Last Login: 5/21/2013
Status: offline
quote:
ORIGINAL: DBono99
Dan
I'm really not sure why you felt the need to make this comment!?!??! The Hitec forum in RCU is not the "official" customer service center and we cannot always put it at the top of our "to do" list; especially on Monday mornings when the phones are typically ringing off the hook. If you need an immediate reply to a question (Sorry, not on the weekends!) then I suggest you call us we're always happy to help. It's not like this was a specific Hitec question so you could have posted this same question in the radio forum where anyone could have helped you.
Alan is qualified to reply in this forum so I did we did not reply since he was already taking care of you.
For the most travel mount the linkage as far out as possible. This goes for Futaba servos as well if you choose to follow through on your threat!
Mike.
Hitec RCD Rep
http://www.hitecrcd.com
Hide Signatures
       Post #: 7
RE: 81's round servo horn - 11/7/2007 2:05 AM
DBono99
Score: 100
Status: offline
Hi Mike Thanks for the response..So then with the round servo arm, the hole farthest away will give me the MOST travel..
Thanks Dan
PS Im just bought my 5th Electron reciever..When are the Neutrons coming out?
Hide Signatures
(in reply to MikeMayberry)
       Post #: 8
RE: 81's round servo horn - 11/7/2007 9:40 PM
MikeMayberry
Score: 104
Status: offline
Correct. Note, it's the opposite for the horn on the control surface as the hole closest to the bottom will provide more travel. So if you can't get enough travel with the outer hole on the round horn, you could move the linkage on the control horn to get even more travel.
Neutrons were delayed until Jan '08
Mike.
< Message edited by MikeMayberry -- 11/7/2007 9:41 PM >
Hitec RCD Rep
Hide Signatures
       Post #: 9
RE: 81's round servo horn - 11/7/2007 10:45 PM
DBono99
Score: 100
Status: offline
Hi Mike "Neutrons were delayed until Jan '08 " WOW!!!
What is going to be the difference between then and the Electrons?
Thanks Dan
PS I've been using all Electrons in my 5 E planes..
Hide Signatures
       Post #: 10
RE: 81's round servo horn - 11/7/2007 11:23 PM
MikeMayberry
Score: 104
Status: offline
End block connector/ Auto shift.
Hitec RCD Rep
Hide Signatures
       Post #: 11
RE: 81's round servo horn - 11/8/2007 12:31 AM
A.T.
Score: 181
Status: offline
quote:
ORIGINAL: DBono99 Hi Mike Thanks for the response..So then with the round servo arm, the hole farthest away will give me the MOST travel.. Thanks Dan <snip>
Thanks Mike, however an exception in this instance as the HS-81 round servo horn does not have holes radiating out from the center, all are equidistant as answered cross Post 3
Regards
Alan T.
Hide Signatures
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.594RCU1
