pilotpete2
VT, USA Status: offline
I use an Ace Digipulse charger, it is designed only for C/10 charging and is timed for 16 hours at C/10, then drops to a trickle charge of C/50. Most chargers that are designed to be used as peak detecting chargers can be set to charge at C/10, but cannot detect a peak, so many are designed to time out if a peak is not detected within 2 hours or so, I believe the Triton is like this, those that do not time out can be used, but just like the lowly "wall wart" have to be stopped by the user. Regards, Pete
_____________________________
"If the woman don''t find you handsome, they should at least find you handy"
