mmattockx
AB, CANADA Status: offline
quote:
ORIGINAL: GuyP I'd appreciate any advice on this build. It's been a while as I say but thanks to forums such as this one Ive learnt and refreshed my memory so much. The control surfaces are solid balsa 1/4", I'm thinking it would be a good idea to cut holes in these aswell to keep the weight down? Any other ideas to make this plane successful are greatly received. Cheers Guy Nice build, it's good to see someone rolling their own instead of a BARF. I would build the control surfaces up from stick stock to ensure the grain runs the way it should for all the areas. It will be lighter, stronger and less likely to warp during covering and in use. Also, make sure you watch the weight of the sticks. Often, stick stock is very hard balsa and weighs a ton. The best option is to cut your own stock from decent sheet, it gives you just the size you need and lets you have a much better selection of wood density and quality that way. Mark
_____________________________
Waco Brotherhood #4
