Recent VK Cherokee Babe build
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Vintage & Antique RC >> Recent VK Cherokee Babe build
Page: [1] 2 3 4 5 6   next >   >>
Login
Recent VK Cherokee Babe build - 11/6/2007 4:56:16 AM
slim_pkns
Status: offline
Howdy y'all!
I got my hands on a VK Cherokee Babe kit. Unfortunately I'm not so experienced with kit building and after looking over the kit contents, I noticed there weren't any instructions. I have a thing for that vintage look and feel and I really want to get into this build but I'm a bit intimidated and I haven't seen any build threads to follow.
I'm thinking of starting a build thread here if I can generate enough interest. I've seen a lot of talk here and on other forums about the VK Cherokee Babe. Mainly about buying & selling and how much you can get for one. Has anyone here recently built one that might be willing to help or would just be interested in give advice, tips, and techniques?
       Post #: 1
RE: Recent VK Cherokee Babe build - 11/6/2007 6:13:11 AM
maxpower1954
Status: offline
Hi Slim, not exactly recent, I built my Cherokee Babe in 1970!
Great flying airplane, with a well-known flaw - under certain conditions, it will get into a flat spin and not be recoverable!
Mine flat spun to the ground three different times with little damage. It could probably use a little more vertical fin and/or rudder area.
Sounds like you may have never built an all-balsa model before. You need a flat building surface you can stick pins into,
I use a building board made from balsa, you can get them from Tower.
Maybe if you came up with specific questions on the process, we could point you in the right direction. It isn't hard, just tedious at times. I would recommend you use Titebond or simliar instead of CA, it gives you more time to set things up correctly. I'm sure this group will be happy to help...Russ Farris
(in reply to slim_pkns)
       Post #: 2
RE: Recent VK Cherokee Babe build - 11/6/2007 6:51:23 PM
slim_pkns
Status: offline
Thanks for the advice. I have built balsa kits before but not for a few years and never one without a step-by-step manual walking through the whole build process. I think I'm going to get ready to start a build thread on this model and see how many others might have built this kit before. The plan isn't too complicated and I would guess the build process is the same for the larger VK Cherokee.
(in reply to maxpower1954)
       Post #: 3
RE: Recent VK Cherokee Babe build - 11/6/2007 7:20:50 PM
Bax
Status: offline
Many times, old kits didn't have step-by-step instructions. You may have some hints or sketches in the plans to show a general building process, but most of your direction came from a study of the plans. On that kit, though, I'd not be sure. I build the .60-size VK Cherokee in 1972, and don't remember if there were actual instructions or just guides in the plans.
It was assumed by many kit makers, then, that if they supplied the parts and plans, you'd know enough to build the model. In those days, by the time you were getting into R/C, you usually had considerable building experience behind you, because R/C usually came after you'd spent some years building and flying free-flight and control-line models. R/C was VERY EXPENSIVE in those days, and you usually learned modeling on something considerably less expensive.
_____________________________
Bill Baxter, Manager Hobby Services/Futaba Service/North America
3002 N. Apollo Dr. Ste. 1 Champaign, IL 61822 USA
Service Phone: 217 398-0007
Email: hobbyservices@hobbico.com
       Post #: 4
RE: Recent VK Cherokee Babe build - 11/6/2007 9:37:05 PM
slim_pkns
Status: offline
I've been looking over the Titebond site and I can't telll which glue would be best for building a balsa kit. Which one is suggested for this small type of job?
(in reply to Bax)
       Post #: 5
RE: Recent VK Cherokee Babe build - 11/7/2007 12:34:15 AM
HighPlains
Status: online
I just looked at the large Cherokee kit stashed away. There is a small sheet of instuctions along with the two plans sheets (which are well detailed). Here is a shot of the top half of the sheet, the bottom is just a parts listing. Perhaps the Babe is about the same.
Click to see fullsize image.
Click for fullsize
In politics if you want anything said, ask a man. If you want anything done, ask a woman - Margaret Thatcher
       Post #: 6
RE: Recent VK Cherokee Babe build - 11/7/2007 1:15:10 AM
slim_pkns
Status: offline
Thanks HighPlains! I can't quite read that but it is probably very similar and it confirms I should be working the wing first. Have you built a VK Cherokee before or just saving it?
(in reply to HighPlains)
       Post #: 7
RE: Recent VK Cherokee Babe build - 11/7/2007 3:02:30 AM
HighPlains
Status: online
I haven't gotten around to building one yet, but I did get a chance to fly one a couple of years ago. Although it looked a bit strange with the stock dihedral, it flew very nicely and tracked well through inside and outside loops. The only Babe I have seen was electric powered and it flew well too.
Both were models that I have always wanted since I was a kid in the late 60's.
       Post #: 8
RE: Recent VK Cherokee Babe build - 11/7/2007 3:22:25 AM
maxpower1954
Status: offline
The original Titebond works just fine, Home Depot or any hardware store has it. I also have used Titebond Carpenters glue, I really can't tell the difference.
Titebond is water resistant and sands OK, unlike Elmer's glue-all.
Russ Farris
       Post #: 9
RE: Recent VK Cherokee Babe build - 11/7/2007 3:44:11 PM
jjscott
Status: online
There was an extensive VK Cherokee (60 size?) build that I found on the web some time ago, but I don't have a link to it. I believe it may have been on some RC Club site. IIRC it was a group build (multiple planes) and had lots of pictures. Maybe someone on this board remembers it & has a link. I'll search around a bit and see if I can find it.
Jim
       Post #: 10
RE: Recent VK Cherokee Babe build - 11/7/2007 3:55:10 PM
jjscott
Status: online
OK, that was easy, #6 on the first page of my search. I'm not sure if I know how to make a link to the page:
Flying Knights Cherokee Build
It's a great build series. Jim
(in reply to jjscott)
       Post #: 11
RE: Recent VK Cherokee Babe build - 11/8/2007 1:14:06 AM
slim_pkns
Status: offline
Thanks for the link Jim! I read the whole thread but found it was mostly over how the club redesigned the old plans to make it easier and even used foam core wings and stab. There was one member who built one from the original kit and he had a few great pictures but no details about his process or how things went. All-in-all it was really inspirational, a very interesting read, and I still learned some things.
I did notice they used wood glue like others advised me to do. I'm wondering about the time it takes to bond. I would guess it takes more than a few minutes and you'd need to keep a bunch of clamps, clothes pins, and stick pins handy. Also, you must have to let things harden overnight, eh?
Great info, thanks again!!!
       Post #: 12
RE: Recent VK Cherokee Babe build - 11/8/2007 3:18:29 PM
jjscott
Status: online
You might read some of the kit assembly manuals to help with the process. Many are quite comprehensive, including directions on which glue to use and when. Try going to the kit airplanes at towerhobbies.com to get their manuals. Top Flite also has manuals. Here are a couple:
Contender
Slow Poke
Jim
       Post #: 13
RE: Recent VK Cherokee Babe build - 11/10/2007 4:14:35 AM
slim_pkns
Status: offline
Thanks everyone for the great feedback. I think I'm going to go for it. I'm going to keep looking for anyone who might have built this model recently. I haven't seen any other build threds on the VK Cherokee Babe so I'm definitely going to start one.
       Post #: 14
RE: Recent VK Cherokee Babe build - 11/10/2007 4:59:25 AM
