flightprep
NJ, USA Status: offline
Hi Slim, Another voice of 'sanity' RE using an OS LA .40 in your Cherokee Babe - when I contacted the O.S. people about the O.S. .35 Max S that came installed in our Cherokee Babe, the exchange was basically that our .35 would behave a lot like an LA .40, except for a higher castor oil% in fuel requirement. I had also asked about the installed muffler (it had no pressurization nipple, etc etc), but the end result is that we are planning on re-installing the side-mounted .35 OS S Max paying attention to the fuel tank geometry. Previous comments RE side mount are well taken. If we can't get tit to work the way we want, we'll tap the muffler and mount a pressure nipple. The OS .35 Max S is, as near as I can tell, is 2 generations behind the LA series (OS Max S, then FP, now LA) - all bushing series. As the motors go, the .35 ought to be fairly close in performancnce to a .40 LA. We have a .40 LA going spare (and a .46 LA as well....) but based on the 'as configured' performance report of the .35 from the former owner/pilot, and knowing the .40 LA and .46 LA series pretty well, I'd argue a .40 LA is a good choice. Thrifty on fuel too, plus the low throttle grunt/torque isn't too bad - .40 LA can cover a lot of applications, just give it enough prop to work at the low end. We're making progress on the rebuild, will get some pics and post in the next weeks. BTW at our field, we have three recognized throttle setting - idle, full, and dead stick. Today all our landings were dead stick - it was a glider day, the field was more like a swimming pool than an airfield! Brgds Flightprep
