WEDJ
Joined: 2/21/2007 From: East Haddam, CT, USA Status: offline
Sanding update Hu Boy! This is different from Polyester resin. Let's start with the fuel hatch. It's only 3x5 inches. Now I admit, I did a quick sanding job on the balsa, it could have been smoother. I put a coat of glass, then 3 coats of Polycrylic, and let it set for 3 days to cure. Dry sand 400 grit - very draggy, loads up the paper. Just like other acrylics. Then I went to 400 grit wet. Sanded fine, made cloudy water, didn't clog the paper, it remined me of the old days. EXCEPT - it doesn't sand down as fast as the polyester used to. I spent 10 minutes on only 15 square inches of finish. And that only brought me down to about 80% dull area. Now, some of it is me, I did the hatch quick, and it has some ups and downs. But I think this finish is harder than the old poly. Good for the plane, bad for the person sanding. Well, I'm committed to this finish, so we will carry on. I will go to 320 wet to do the body, I hope that will help. Also, I am leaving the finish less than perfect, because I think the Epoxy primer will cover up better and sand easier. Tonight the second coat of finish went on the body. Oh, I almost forgot - after the first coat on the body dried for 2 days, i scuffed the overlap areas with 100 grit dry. It powdered up OK, and softened the edge, but felt draggy, but didn't bind the paper. So the overlap edges were smoothed before tonight's coat of finish. Also, I had one drip spot, that stayed like a drop, and was cloudy and soft. An Xacto snip and 100-grit scuff and it was gone. It was at the tip of the rudder. There's no photos, because they didn't really show ANYTHING, much less the subtle differences I am trying to explain.
