RE: PassTime Perigee Build thread
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pattern Flying >> Classic Pattern Flying >> RE: PassTime Perigee Build thread
Page: <<   < prev  2 3 4 5 6 7 8 [9] 10 11   next >   >>
Login
RE: PassTime Perigee Build thread - 2/24/2008 3:29:16 AM
WEDJ
Status: offline
OK, lost the camera for a while.
so, after finishing the wing covering, there was this little problem, the overlap of the fabric covering.
No problem, just paint a little primer on the overlaps and sand down, right? That's what I thought. In reality, the primer went on OK, but when I sanded it, the solartex finish was scuffed up. Then I painted it, and the damage was visible because of the nice shiny epoxy finish. At first look, it is fine, but I will have to re-finish spots with 400 wet and then re-spray. No big deal.
Click to see fullsize image.
Click for fullsize
Click for fullsize
(in reply to WEDJ)
       Post #: 201
RE: PassTime Perigee Build thread - 2/24/2008 3:30:49 AM
WEDJ
Status: offline
And, I decided to do the canopy in Yellow Rit dye.
(in reply to WEDJ)
       Post #: 202
RE: PassTime Perigee Build thread - 2/27/2008 2:54:29 AM
WEDJ
Status: offline
OK, so progress, no matter how slow, is steady.
This part of a build always bogs down for me. So much detail, so little worth sharing on a build thread. OK, here's a shot of the install of the nose gear steering. Not much I can say, it is really very basic. Cut a slot, CA the nyrod outer, fill in the blanks with Epoxolite, sand smooth. Any questions?
Click for fullsize
(in reply to WEDJ)
       Post #: 203
RE: PassTime Perigee Build thread - 2/27/2008 2:59:53 AM
WEDJ
Status: offline
Moving rearward, Took about 4 or 5 nights to do all the fillets around the tail section. Again, nothing fancy, just basic building. Here's how it goes:
Mix Epoxolite
Smear lots into corner with craft stick
Run craft stick once down the center, slow and heavy.
Use scrap wood to scrape the excess from the thin edges
drip several drops of water onto semi-finished fillet
Use wet finger to do final smoothing
Next day, touch up with 220 grit sandpaper
Ready for primer.
Click for fullsize
Click for fullsize
< Message edited by WEDJ -- 2/27/2008 1:17:09 PM >
(in reply to WEDJ)
       Post #: 204
RE: PassTime Perigee Build thread - 2/27/2008 5:01:09 PM
Free Bird
Status: offline
Looking good Nic!
(in reply to WEDJ)
       Post #: 205
RE: PassTime Perigee Build thread - 2/28/2008 6:07:18 PM
Jim_Purcha
Status: offline
Question? What's the manufacturer of the nose gear link you're using?
Jim
quote:
ORIGINAL: WEDJ
(in reply to WEDJ)
       Post #: 206
RE: PassTime Perigee Build thread - 2/28/2008 7:21:49 PM
WEDJ
Status: offline
Hi Jim,
The firewall brackets are Du-Bro, the gear leg is a tower Kaos 40 replacement set, and a Du-bro EZ mount steering arm. Here's a link for the arm: http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXD848&P=7
< Message edited by WEDJ -- 2/28/2008 7:26:32 PM >
(in reply to Jim_Purcha)
       Post #: 207
RE: PassTime Perigee Build thread - 2/28/2008 8:59:25 PM
Jim_Purcha
Status: offline
Thanks, Nick. I'll have to check the LHS after work for these.
Jim
(in reply to WEDJ)
       Post #: 208
RE: PassTime Perigee Build thread - 3/2/2008 3:04:32 AM
WEDJ
Status: offline
Tonight at the grocery store I found RIT yellow dye (woot!)
Also decided to cut the hinge slots before painting, never hurts to have a little more fuel proofing in the recesses.
       Post #: 209
RE: PassTime Perigee Build thread - 3/8/2008 11:21:11 PM
WEDJ
Status: offline
Let me just say,
"NOTE TO SELF"
do not put plastic canopy in boiling dye water. Let the water cool first.
I remember dying canopies in the past. I must have forgotten that you need to cool the mixture first. Oh well, replacements have been ordered.
Click for fullsize
(in reply to WEDJ)
       Post #: 210
RE: PassTime Perigee Build thread - 3/9/2008 12:48:31 AM
Jeff Worsham
Status: offline
Sir! That looks like something I would do!! Made me chuckle with the reminder that we're all human....Thanks for doing this build thread and for posting this pic!
(in reply to WEDJ)
       Post #: 211
RE: PassTime Perigee Build thread - 3/9/2008 1:08:07 AM
WEDJ
Status: offline
Yes, this thread has several of my "oops" in it. Hey, I'm not perfect. I must admit, I do like the color of the yellow canopy, I think it will look good on the finished Perigee when I dye the next one.
(in reply to Jeff Worsham)
       Post #: 212
RE: PassTime Perigee Build thread - 3/13/2008 1:33:18 AM
WEDJ
Status: offline
So last Saturday I'm placing my order w/ Tower for the canopy, and I decided - Hey, just get two! So I did, and they arrived today.
I have multiple agendas here:
Spare in case I happen to F#$% another one up
Dye one yellow and one blue, and then decide which looks best (yes, I bought 2 colors of RIT)
Hey, maybe I'll need another in the future.
Have now hinged the tail, stay posted.......
Click for fullsize
(in reply to WEDJ)
       Post #: 213
RE: PassTime Perigee Build thread - 3/15/2008 2:26:48 AM
WEDJ
Status: offline
For those faithful followers, no explaination needed!
Click for fullsize
(in reply to WEDJ)
       Post #: 214
RE: PassTime Perigee Build thread - 3/15/2008 12:20:35 PM
dhal22
Status: offline
not being one of those faithful followers, but that looks like a canopy dyed in lukewarm yellow water to me.
david
< Message edited by dhal22 -- 3/15/2008 12:21:17 PM >
(in reply to WEDJ)
