coro_sk -> RE: New 1100 mAh A123 available everywhere and no word here! (12/23/2007 11:23:27 AM)
Right now I am curious whether the single post appeared yet, about A123 M1A cell failing with open circuit, was the function of internal fuse going to open circuit, or perhaps failed tab, hopefully? I would be glad if it would be just the tab falling off.. Anyway, I will backup receiver power in my full mould electric powered glider. But I will let it be in small foamies. And in addition, few small diodes hooked to balance port, may help bridging the open cell. Motor must cutoff immediately, but receiver and servo power may run thru balance port, bypassing open circuited cell thru diode, and use power of remaining cells. Diodes will be added to Cellshield-like DIY device. It just have to be avoided to reverse connection (it would burn diodes immediately). And I dont expect troubles with powering just the receiver by 2s pack, as the currents are small compared to what electric motor consumes - but with tabs secured, or wires soldered to cells.
