RE: New 1100 mAh A123 available everywhere and no word here!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> A123Racing Support >> RE: New 1100 mAh A123 available everywhere and no word here!
Page: <<   < prev  1 2 3 4 [5] 6   next >   >>
Login
RE: New 1100 mAh A123 available everywhere and no w... - 1/1/2008 4:04:17 PM
everydayflyer
Status: offline
It will work howeever the 1100s have higher IR and their energy density is lower.
I have ran a 4S of each in parallel and flight time was approx. 25% more and the packs did not discharge evenly.
All things considered adding a cell to the 2300 pack makes more sense as you will increase flight time as much with less cost and weight if you use Throttle management.
Note: To be able to add a cell your ESC must be able to handle the higher voltage.
Charles
< Message edited by everydayflyer -- 1/1/2008 4:06:17 PM >
(in reply to Max1965)
       Post #: 101
RE: New 1100 mAh A123 available everywhere and no ... - 1/1/2008 4:27:44 PM
Max1965
Status: offline
Charles:
Did the batteries get hot because of the uneven discharge?
I am using the MEC packs and I can't add a fifth cell so I figured a 2s 1100 would work...course I guess I could rig up a one cell 2300mah battery.
Throttle management? Not me I'm a nonconformist and speed demon.
The question was just "I wonder" type. Thanks
(in reply to everydayflyer)
       Post #: 102
RE: New 1100 mAh A123 available everywhere and no w... - 1/1/2008 6:36:42 PM
Mr.Pibb
Status: offline
quote:
ORIGINAL: Max1965
Just wondering something.
Could these 1100mah cells be used as "splits" along with the 2300mah cells? I am thinking along the line of running a 4s1p 2300mah pack with a 2s 1100mah pack in parallel..... Any idea if this would work and what would be the gain in flying time? Right now I am flying about 5 minutes full out on a 2300mah 4s1p pack but I have enough room in the plane for an additional 2s 1100mah pack and any extra flight time would be nice.
Inquiring minds?
You'd need to make it a 4s1p 2300 and a 4s1p 1100 hooked up in parallel or you'll start some fireworks!
       Post #: 103
RE: New 1100 mAh A123 available everywhere and no w... - 1/3/2008 3:27:02 PM
dirtybird
Status: offline
I have been charging my 3c 1100 battery directly from a 12V lead acid battery with a 1 ohm 10 watt resistor in series to limit the current. I have a sw that shorts out the resistor. I throw that sw after the pack has charged a few minutes. I can recharge in about 10-15 minutes. It seems to work OK.
       Post #: 104
RE: New 1100 mAh A123 available everywhere and no w... - 1/3/2008 3:38:34 PM
everydayflyer
Status: offline
quote:
ORIGINAL: dirtybird
One ohm sounds high and 10 watts sounds to low.
What gauge and length leads are you using. What is the pack voltage and 12Pb voltage before start of charge and during charge and what is the starting amp. rate?
pack at 8 volts and Pb at 12 volts 1 Ohm resistence = 4A flow and 16 watts.
Charles
< Message edited by everydayflyer -- 1/3/2008 3:43:46 PM >
(in reply to dirtybird)
       Post #: 105
RE: New 1100 mAh A123 available everywhere and no ... - 1/3/2008 8:11:42 PM
dirtybird
Status: offline
#20 wire about 3' long
Pb start voltage 12.2V
Pack start voltage 9.6
With resistor in the line charge rate is 1.8A, that is 3.24W
When the resistor is switched out the charge rate is 3-4 amps. When it drops to .2 amp I consider it fully charged.
These are measured valuse not calculated. (Except for the W)
If the pack is fully depleted the voltage will recover to 9.6 when the load is removed. That is if you have not ruined a cell
       Post #: 106
RE: New 1100 mAh A123 available everywhere and no ... - 1/10/2008 1:02:39 AM
everydayflyer
Status: offline
I know how to charge with resistor and wire I just wondered why you were using such a high Ohms resistor. I see you are slow charging.
I charge a 3S 2300 pack in 5-8 minutes.
http://www.rcuniverse.com/forum/m_6477096/tm.htm
Charles
       Post #: 107
RE: New 1100 mAh A123 available everywhere and no ... - 1/10/2008 9:54:24 AM
kent_man
Status: offline
I was thinking of picking up a couple of the BD vxp packs to make 2s or 3s batts for my 1/18th brushless truck. I have no experience with lipo's though. I have a Dynamite Prophet Plus charger that will charge 6-7 cell NiMh. What charger should I buy? I'm probably asking for the impossible, but I want a relatively inexpensive balancer charger that would be good for these batts and possibly other lipo's down the road. I would like one that had it's own power supply for ease.(unless it is better and relatively comparable price wise to buy a seperate power supply) Should the balancer be seperate or built into the charger?
What would you recomend?
Thanks in advance,
kent_man
_____________________________
Savage X 4.6, RC18T Factory Team Kit with 6800 mamba, RC18R Niteline
       Post #: 108
RE: New 1100 mAh A123 available everywhere and no ... - 1/10/2008 2:01:17 PM
Red Scholefield
Status: offline
quote:
ORIGINAL: kent_man
Thanks in advance,
kent_man
CellPro 4S
Red S. AMA 951
R/C Battery Clinic
www.rcbatteryclinic.com
(in reply to kent_man)
       Post #: 109
RE: New 1100 mAh A123 available everywhere and no ... - 1/10/2008 2:16:26 PM
kent_man
Status: offline
What power supply should I get for the CellPro? Pyramid? How many amps?
(in reply to Red Scholefield)
       Post #: 110
RE: New 1100 mAh A123 available everywhere and no ... - 1/10/2008 2:31:16 PM
kent_man
Status: offline
Ok I guess I need a minimum of 5 amps 25 amps is a little overkill. So which power supply would you recomend? Maybe I should get a high amp one in case I get a different charger.
       Post #: 111
RE: New 1100 mAh A123 available everywhere and no ... - 1/10/2008 7:19:57 PM
SS Pede
Status: offline
You should probably get something like a 15 amp power supply. I have a Radio Shack one that works well, but there are many choices.
       Post #: 112
RE: New 1100 mAh A123 available everywhere and no ... - 1/10/2008 11:32:02 PM
thaus
Status: offline
There is an ad on rc universe which offer a 10 amp supply for $22. I have one and really like it. This is the best kept secret in the rc hobby.
(in reply to SS Pede)
       Post #: 113
RE: New 1100 mAh A123 available everywhere and no ... - 1/11/2008 12:11:04 AM
SinCityJets
Status: offline
I wouldn't call 10amps the best kept secret.....Jacked Up Customs makes a great 25amp unit. (available below)
1100mah packs are not going to be good for the 1/18th....well, it will for about 3 minutes. Just an fyi.
www.sincityjets.com
A123 Battery Packs / Trigger Valves / Stretchy Covers / Smart-Fly / Fei Bao / JetCat / Jet Central
(in reply to thaus)
       Post #: 114
