Bob Pastorello
Joined: 2/23/2002 From: El Reno, OK, USA Status: offline
quote:
ORIGINAL: thaus I have had trouble balancing an 1100 A123 pack with the fma cellpro 4s. I could ballance the pack using a resistor to lower the high voltage cell and charging the pack again (with several iterations). So I sent the battery and charger to FMA. They returned both saying there is a bad cell in the pack. I bought another pair of 1100 cells and am getting the same results: a 300 mv difference between cells. What is wrong? Contact FMA. This is a "known" issue, and latest firmware update to 2.08 resolves this 1100 VPX cell peaking issue. (Sorry to crash the A123 thread, folks....just saw thaus' post, and wanted to help)
_____________________________
Bob Pastorello www.rcaerobats.net Learn from others...you can't live long enough to make all the mistakes yourself....
