won't roll backwards    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> won't roll backwards
Page: [1]
Login
won't roll backwards - 11/7/2007 8:34 AM
shoota0075
Score: 100
Last Login: 5/12/2013
Status: offline
ok, i installed a new STEEL clutch bell ,intallation went great very easy, but now when i put my tsunami on the ground i can push it foward with no problem, but i can not roll it backwards ,it's like all the wheels lock up, did i miss something or is this not a very big problem?
_____________________________
Louisville Cardinals all the way
Hide Signatures
       Post #: 1
RE: won't roll backwards - 11/7/2007 2:32 PM
cen123
Score: 100
Last Login: 11/11/2007
Status: offline
How did you check the gear mesh? It's probably too loose.
Hide Signatures
(in reply to shoota0075)
       Post #: 2
RE: won't roll backwards - 11/7/2007 3:21 PM
shoota0075
Score: 100
Status: offline
oh oh ,gear mesh?
Hide Signatures
(in reply to cen123)
       Post #: 3
RE: won't roll backwards - 11/7/2007 3:43 PM
Chubbysdad
Score: 100
Last Login: 12/22/2009
Status: offline
gear mesh is the play between the spur gear and the clutchbell. You could have it too tight, too loose which will destroy your gears.
Cen truggy, Bigfoot 1/5th, Cen buggy, Mg16, Redcat Earthquake, Redcat Drifter
Hide Signatures
       Post #: 4
RE: won't roll backwards - 11/7/2007 4:14 PM
Syclone354
Score: 100
Last Login: 12/29/2012
Status: offline
i had mine too tight once and it wouldnt roll backwards. with it set perfect it would roll forward perfect without a wisper, and would have just a light drag when rolling backwards
Redcat Avalanche
Redcat Tsunami
Hide Signatures
(in reply to Chubbysdad)
       Post #: 5
RE: won't roll backwards - 11/8/2007 12:23 AM
hrdcoreglf
Score: 100
Last Login: 12/10/2009
Status: offline
When you mount the engine in the vehicle, cut a small strip of printer paper about 2 inches long. When you mest the spur gear and clutch bell, make sure you crimp the paper nice and tight in between the gears. Don't put enough presure to put the vehicle through you table, but enough to make sure your gears are meshed tight. Pull the paper out and you have a good gear mesh. Try that and see if it help.
Wisdom is only as good as the person you give it to.
Hide Signatures
(in reply to Syclone354)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.063RCU1
