Reload this Page >
just started m32 Recovery Vehicle
Old 11-12-2007, 01:26 PM
Leo2A6 Owner
Leo2A6 Owner's Avatar
Default RE: just started m32 Recovery Vehicle
Actually i stand corrected ist a composite hull, with spaced armor in front to the drivers and radio ops hatches.
Old 11-12-2007, 01:32 PM
septon
thank if you could post the external ones too that would be great i may also do a M32 with a welded hull to as i have a tamiya hull spare
Old 11-12-2007, 01:36 PM
Leo2A6 Owner
Sounds good. Let me go through and edit for size and contrast and il post them in a bit. I took about 50 pics. Youll see that his has been sitting a while. It has sink into the ground a bit. All th track is there. Aside from some road wear its in pretty restorable condition.
Old 11-12-2007, 01:56 PM
Leo2A6 Owner
ok here we go.
ID:	802351   Click image for larger version
ID:	802352   Click image for larger version
ID:	802353   Click image for larger version
ID:	802354   Click image for larger version
ID:	802355   Click image for larger version
ID:	802356   Click image for larger version
ID:	802357   Click image for larger version
ID:	802359   Click image for larger version
ID:	802360   Click image for larger version
ID:	802361   Click image for larger version
Old 11-12-2007, 01:59 PM
Leo2A6 Owner
Next
ID:	802370   Click image for larger version
ID:	802371   Click image for larger version
ID:	802372   Click image for larger version
ID:	802373   Click image for larger version
ID:	802374   Click image for larger version
ID:	802375   Click image for larger version
ID:	802376   Click image for larger version
ID:	802378   Click image for larger version
ID:	802379   Click image for larger version
ID:	802380   Click image for larger version
Old 11-12-2007, 02:03 PM
  #31
Leo2A6 Owner
more
ID:	802382   Click image for larger version
ID:	802383   Click image for larger version
ID:	802384   Click image for larger version
ID:	802385   Click image for larger version
ID:	802386   Click image for larger version
ID:	802387   Click image for larger version
ID:	802388   Click image for larger version
ID:	802390   Click image for larger version
ID:	802391   Click image for larger version
ID:	802392   Click image for larger version
Old 11-12-2007, 02:07 PM
  #32
Leo2A6 Owner
even more
ID:	802398   Click image for larger version
ID:	802399   Click image for larger version
ID:	802400   Click image for larger version
ID:	802401   Click image for larger version
ID:	802402   Click image for larger version
ID:	802403   Click image for larger version
ID:	802404   Click image for larger version
ID:	802406   Click image for larger version
ID:	802407   Click image for larger version
ID:	802408   Click image for larger version
Old 11-12-2007, 02:09 PM
  #33
Leo2A6 Owner
last ones. I hope i was able to get some useful detail shots for you.
ID:	802410   Click image for larger version
ID:	802411   Click image for larger version
ID:	802412   Click image for larger version
Old 11-12-2007, 02:10 PM
  #34
septon
thank you very much these photos will be so much help with my build
Old 11-12-2007, 02:15 PM
  #35
Leo2A6 Owner
Your welcome
I hope others find it useful as well.
Old 11-12-2007, 08:25 PM
  #36
The_Stuff
The_Stuff's Avatar
awesome pictures. that tank should most definitely be restored. Still amazed at how much it has sank.
Old 11-12-2007, 10:37 PM
  #37
nemesis4u
My Feedback: (77)
nemesis4u's Avatar
IF ANYONE WANTS THOSE CAST HULLS YOU CAN ORDER THEM.... NAME IS NICK AGUILAR FROM CORPUS CHRISTI TEXAS...He is a member of TEXAS ARMOR ASSOCIATION.... and HIS EMAIL IS:
[email protected]
Tell him TOMAS sent ya!!!!!!!!!!!!!!!!!!!!!!!!!
Old 11-16-2007, 09:14 AM
  #38
pattoncommander
pattoncommander's Avatar
Which winch are you interested in? The main winch had a huge drum inside at the rear of the upper superstructure. It fed through the box at the front which has sets of pulley wheels at the sides. A smaller winch fed at the top front of the same structure On the B-1 and B2 models and M-32A1B3, the smaller winch was used to raise and lower the boom by using a bar that locked into where the mortar base was and had a pulley at ther top end. The cable fed through the pulley and back to the boom A frame and this eliminated the need for the bracket on the right side boom. The bracket had a lock bracket on the hull which held the boom in place when errected. A short cable was placed into one of the 3 points on the bracket and into a flange on the right sprocket. The driver would raise the boom by inchiong forward until the boom was straight up, then using the brakes, would ease forward until the bracket was locked into place. The boom had no additional movement possibilities. Removing engines or heavy items was done by the winch and A frame on the boom. The main cable was carried either backed up into the front box or let out a bit and locked into a front towing eye.
Pic of an M-32A1B3 showing the boom lifting mechanism. I have a pic of our M-32 in Korea but can't find it...will have to look. I ised to drive it for kicks and was able to leatrn a few things about it..
Old 11-16-2007, 09:46 AM
  #39
pattoncommander
I couldn't locate my M-32 without re-shooting the photo itself, but here are some pics of the 1;35 scale models I did for our museum, which shows the lifting bracket, cables and gear and a couple more photos of the M-32A1B3 showing details and stowage, with boom raised. My museum displays are extremely accurate and although a 1;1 scale is better, these at least, show the gear as seen in the normal operating mode. These may be of help.
Bill
ID:	804918   Click image for larger version
ID:	804919   Click image for larger version
ID:	804920   Click image for larger version
Old 11-16-2007, 09:54 AM
  #40
pattoncommander
Forgot one very interesting thing on the M-32A1B3,,,,note the roller under the winch cable box on front. This was designed to string out the cable through the bottom escape hatch, over the roller and to whatever it was going to drag away. this provided a means for a crewman to actualy hug the ground and get the cable attached without exiting from top or standing to extract the cable. You learn some neat things researching for a museum.
Old 11-16-2007, 04:13 PM
  #41
septon
thanks for the info
heres some more pics of my M32 build
ID:	805119   Click image for larger version
ID:	805120   Click image for larger version
Old 11-17-2007, 07:26 PM
  #42
Leo2A6 Owner
that looks really good. Makes me want to get a 1/16 sherman now and do the one at Ft Knox
Old 11-17-2007, 08:29 PM
  #43
Panther F
Panther F's Avatar
What would be even cooler is that it can actually recover a vehicle!
Jeff
Old 11-17-2007, 08:35 PM
  #44
septon
that would be cool
Old 11-18-2007, 12:08 PM
  #45
YHR
YHR's Avatar
Nice build thread. Interesting and informative.
Old 11-18-2007, 06:48 PM
  #46
septon
heres some more pics of my M32 with my firefly
ID:	806707   Click image for larger version
ID:	806708   Click image for larger version
ID:	806709   Click image for larger version
ID:	806710   Click image for larger version
ID:	806711   Click image for larger version
Old 11-18-2007, 08:49 PM
  #47
hdbeast
hdbeast's Avatar
NICE, both look great, the Sherman was a cool build, I think some of you guys should be extra nice to Santa (wife) and try a Sherman build. They do cost a bit more but are a nice and fun tank to build.
Old 11-19-2007, 06:05 PM
  #48
septon
bit more done tonight
got the Internal crew deck started
ID:	807505   Click image for larger version
Old 11-19-2007, 06:08 PM
  #49
septon
and the winch that works i have tested it and it will lift a tamiya 1\16 gearbox
Old 11-24-2007, 08:15 PM
  #50
septon
been on the net and found some pics of a M32 with a mine roller called a T1E1 Earthworm started to make it tonight.
will post pics soon
ID:	810929   Click image for larger version
ID:	810930   Click image for larger version
ID:	810931   Click image for larger version
