RE: CEN MG10 or MG16 for first nitro?
Tower Hobbies
Logged in as Guest
  Printable Version
Team Losi Muggy - RTR
Seller:  PastorVee
Details:   $1,100.00   |  10/10/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> CEN Racing >> RE: CEN MG10 or MG16 for first nitro?
Page: <<   < prev  1 [2]
Login
RE: CEN MG10 or MG16 for first nitro? - 11/17/2007 6:19:19 AM
Zamboni_Assasin
Status: offline
Once again, I cant thank you enough.....yes I was wondering about accessability of the LSN cuz I had heard some gripes about that, but never thought it would be as easy as a pocket screwdriver, lol......and so was your HSN set ok from factory?
(in reply to muck76)
       Post #: 26
RE: CEN MG10 or MG16 for first nitro? - 11/17/2007 1:43:42 PM
muck76
Status: offline
factory is 2-2.5. you will have to lean it some once break in is done. Your area and temps outside will determinee than.
With it being cold here i will eventually start wrapping the head to help keep heat in so it does not get to lean. See as it gets colder outside people have a tendancy to lean out the fuel mixture to keep temps up. That is wrong. It leans out the oil mixture also. If it is close to freezing outside i use a baby sock around my head. Others use alum foil. I wonder if you should hold off on making any cooling holes in the windshield right now as to help keep the heat in and not have to worry about wrapping the head.
My suggestion would be to hop over to the engine thread and post a question similar to " I live in CA and am getting my first nitro, what do i need to do to keep the mixture and temps correct for colder weather" I bet some one in CA will be able to help give you a better idea with your climate there.
BTW what temp is it outside right now? I am about 40 degrees F.
(in reply to Zamboni_Assasin)
       Post #: 27
RE: CEN MG10 or MG16 for first nitro? - 11/17/2007 7:02:49 PM
Zamboni_Assasin
Status: offline
Ya I had contemplated that already, whether or not to cut any holes until spring and I figured I would hold off for the reasons you said, keeping the engine warmer and I thought that would help to warm the air inside the body going directly into the carb a little bit......Our temps are about the same, a little cooler today but usually around 0 to +5C (35-40F)
       Post #: 28
RE: CEN MG10 or MG16 for first nitro? - 11/18/2007 11:38:00 AM
Zamboni_Assasin
Status: offline
Let me know how your exhaust fix works.....sounds like it might be as easy as ordering a second stock canister for the second outlet end!!! and if it is I was to get one ordered asap lol
       Post #: 29
RE: CEN MG10 or MG16 for first nitro? - 11/22/2007 5:05:31 AM
muck76
Status: offline
hey Zam i have finished my upper arm mod.
I have the parts here today for the exhaust but little time to tackle that until the weekend. It also is wet weather so i may not be able to even test it yet.
Here is the link:
http://forums.thetoyz.com/index.php?showtopic=1165&pid=9308&st=0&#entry9308
< Message edited by muck76 -- 11/22/2007 5:06:25 AM >
       Post #: 30
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.438RCU1
