remcl1
FL, USA Status: offline
I would also vote for the Profile, but it has to have a better design in the nose than the 90 version. The fusion that Z man gave to one of my students, due to not wanting to hassle with the china coat any longer, lost the entire nose. This plane was still considered new. After about his third day of flying it, he started it and wham the entire nose tore right off. He was on the ground, so the rest of the plane was not harmed. Thank god no one was standing near by. He has it fixed now and it is more solid and has less vibration than when it was new. Vote for slab with a better designed nose, and the use of ultracoat. I would also like to see a movable wing like on the fatty Giles that you sell. As long as you are going for the Imac/freestyle crowd, I think this would be a help. The few 90 fusions that I have seen were tail heavy with the lighter saito 100. My 80 inch Edge 540 was a little tail heavy with the saito 180. It would be nice to be able to move the wing if you had a lighter engine and wanted to do pattern work without adding any nose weight.
_____________________________
http://web.tampabay.rr.com/rmclarty/
