Os 120 4 stroke overhaul help needed
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> Os 120 4 stroke overhaul help needed
Page: [1] 2   next >   >>
Login
Os 120 4 stroke overhaul help needed - 11/11/2007 4:18:00 AM
Cub Man
Status: offline
Hey guys just picked up a fs series os 120 4 stroke. It is an old one most that I have seen have one valve cover for both valves. This one is a cove for each valve. Any way this engine has been setting for years. I need to overhaul it. I started tearing it down. I removed the set screws that hold the pins that the rocker arms are on. Now how do I get the pins out? Any help is great as this is my first 4 stroke. I have been in the hobby 14 years and just now getting a 4 stroke What is the best stuff to use to clean an engine up
_____________________________
The Cub Den
www.thecubden.org
       Post #: 1
RE: Os 120 4 stroke overhaul help needed - 11/11/2007 4:36:40 AM
w8ye
Status: offline
I wouldn't remove these pins unless something is broken about them?
You cannot get new parts for this engine from the OS sources but the bearings and ring are commonly alailable. That's generally all you will need.
I've attended the CutFinger Institute of DirtNap University for years but never did graduate....
Club Saito Member #7
Original AMA #31261
(in reply to Cub Man)
       Post #: 2
RE: Os 120 4 stroke overhaul help needed - 11/11/2007 1:31:28 PM
Cub Man
Status: offline
one of the push rods coming up that works the valve is bent
The Cub Den
www.thecubden.org
(in reply to w8ye)
       Post #: 3
RE: Os 120 4 stroke overhaul help needed - 11/11/2007 2:25:11 PM
w8ye
Status: offline
When you remove the head, the pushrod will fall out
Original AMA #31261
       Post #: 4
RE: Os 120 4 stroke overhaul help needed - 11/11/2007 2:28:30 PM
Cub Man
Status: offline
It appears to be two allen bolts under the rocker arms that hold the head on. I dont think i can pull the screws with the rockers in place
The Cub Den
www.thecubden.org
(in reply to w8ye)
       Post #: 5
RE: Os 120 4 stroke overhaul help needed - 11/11/2007 2:37:47 PM
w8ye
Status: offline
I'm sorry, I have never owned a pre -Surpass double rocker cover OS 120. I've ran, adjusted, and flown them but never had to disassemble one. My overhaul experience has been with the newer engines.
I do know how to set the cam timing and adjust the valves.
Original AMA #31261
       Post #: 6
RE: Os 120 4 stroke overhaul help needed - 11/12/2007 4:09:26 PM
Waco Driver
Status: offline
Tap the rocker arm shafts out using a 1/8' pin punch or a piece of music wire using care not to damage the nylon washer on the inside face of each rocker arm. Tap the shafts inboard towards the center of the cylinder until the rocker arms can be removed, then push the shafts outboard to remove. They are probably stuck with congealed oil.
Soaking the engine in some fuel or methanol overnite will probably loosen things up.
MAAC 6273 L
(in reply to w8ye)
       Post #: 7
RE: Os 120 4 stroke overhaul help needed - 11/12/2007 4:13:25 PM
Cub Man
Status: offline
Thanks for the help. First I will say guys that I will probably never sale the engine as it was a on a plane that belong to a flying friend that has passed away. I’m looking to get it back up and running so that this plane will see flying time again.
The Cub Den
www.thecubden.org
(in reply to Waco Driver)
       Post #: 8
RE: Os 120 4 stroke overhaul help needed - 11/12/2007 5:19:00 PM
Ed Cregger
Status: offline
Cook it in antifreeze and do not disassemble it any further than absolutely necessary. As Jim said, parts are no longer available from the US OS importer and can be very difficult to find.
This engine has gained one heck of a following since it was dropped from production. It is a sweet running engine when right, but there are a few caveats. Pay particular attention to the high speed mixture. Never - ever - let it get even close to running at absolute peak rpm. The crankcase has been known to break in two if the engine backfires. Keep it fat beyond reasonable doubt.
The pushrod should be able to be straightened with a soft mallet and a hard wood, or steel, surface. Just take your time and be sure it doesn't fly off somewhere never to be found again.
I bench ran my FS-120 (official designation) only since it was one of the first imported into the country and I didn't have a model of the proper size for it. It ran fine on the bench, lots and lots and lots of times before I sold it to a friend, who sold it to a friend. The friend's friend had a model, mounted it up and flew it one summer. Before the summer was out, he had to replace the rocker shafts and associated parts due to a lack of lubrication. Another caveat.
Good luck getting her going.
Ed Cregger
Artisan
"Flying models since the Fifties - I'll get the hang of this yet!!!"
       Post #: 9
RE: Os 120 4 stroke overhaul help needed - 11/12/2007 5:26:50 PM
w8ye
Status: offline
In the field where I flew in Alabama, A well known modeler was gently flying his Monocoupe with a double rocker 120 when "BANG" the bottom of the crankcase blew off.
Original AMA #31261
(in reply to Ed Cregger)
       Post #: 10
RE: Os 120 4 stroke overhaul help needed - 11/13/2007 12:15:54 AM
blw
Status: offline
Yes, it did go bang right over my head!
It had a couple of microseconds of the engine reving up and it went. It did blow out the whole bottom of the crankcase. I think it was in two pieces in the bottom of the cowl. The guy had mentioned that he thought it was running hotter than normal, but he flew it again that day.
The ultimate responsibility of pilots is to fulfill the dreams of the countless millions who can only stare skyward...and wish.
(in reply to w8ye)
       Post #: 11
RE: Os 120 4 stroke overhaul help needed - 11/15/2007 3:17:17 AM
donkey doctor
Status: offline
Hello; I am in the process of overhauling an OS FS120 right now, there are a few things that no other engine has; The rockers have to come off to expose the rocker carrier and allow access to the head bolts. There are plastic shims on either side of the rockers that are tough to get back in. You can find parts, if you need them, no exhaust pipes though. Noel Jensen has parts.
Upon re-assembly I found that the new push rods were longer then original, now I have to find shorter adjusters somewhere, or make them.
The engine I am overhauling had excessive cam wear and needed a cam and lifters and pushrods, due to a lubrication problem. I think the woner tried to lean it out for more power then it can make, then the damage happened.
(in reply to blw)
       Post #: 12
RE: Os 120 4 stroke overhaul help needed - 11/15/2007 4:58:42 AM
jessiej
Status: offline
quote:
ORIGINAL: w8ye
I bench ran my old double rocker 120 a couple of weeks ago. It is a very smooth runner, but I had been unaware of the potentially explosive nature of these handsome old engines! Thanks to these posts I will be extra careful about lean runs and lubrication.
The example I have was purchased new. Aside from bench running I had it in a Lazy Ace for a few flights then replaced it with an OS 1.06FSR. I think it is a more attractive engine than the current crop, but that is purely subjective.
jess
(in reply to w8ye)
       Post #: 13
RE: Os 120 4 stroke overhaul help needed - 11/15/2007 6:18:33 AM
submikester
Status: online
I've got one of these and it's a pretty sweet little engine. Never a problem and I always run it a bit rich.
(in reply to jessiej)
       Post #: 14
RE: Os 120 4 stroke overhaul help needed - 11/19/2007 12:51:59 AM
Cub Man
Status: offline
Good news. The rod was not bent it was just popped out of socket. I will give the engine a good cleaning and put it back together. Everything looks to be in great shape.
The Cub Den
www.thecubden.org
