Geistware
GA, USA Status: offline
Chevelleflyer, Their are no stubpid questions in life. While technically you are correct, the charger can charge a dead pack at a minimum of .5C and a max of 1C. The minimum is set because the charger has an auto shutoff feature that will stop the charger after 2 hours (0.5C) and the max is set by the manufacturer of 1 hour (1.0C). I would recommend that you set your RX to charge at a minimum of 0.6 amp and the TX at a minimum of 0.3 amp. This will keep your battery's internal temps lower and less stress on the pack. THis is a PERSONAL preference and is not based on any data collected or read. quote:
ORIGINAL: Chevelleflyer This will probably sound like a stupid question, but since I'm a newbee, too, I have to ask. I just bought the Hobbico MKII, thanks to many of your recommendations, and before I use it, I want to make sure I don't mess up. I have a new JR radio that (according to the specs. in the manual) has a 600 MA tx and 1100 MA receiver battery. So, when recharging the receiver battery, do I turn the dial to 1.1 amps and when recharging the tx, put the dial at 0.6 amps? I did read the instructions with the charger, but I think it assumes that you know what you're doing already. I guess I'm a little confused because I thought that a tx has 8 AA size batteries in it, but the receiver battery is a small 4 or 5 cell pack. If so, why would the smaller pack have more power? I would think that the tx would require a higher charge rate. Thanks.
_____________________________
Aircraft Proving Grounds http://www.rcaircraft.net/ Information on the building and flying of Radio Control Aircraft. Site for hobbyist in the R.C. Aircraft modeling world.
