RE: Xray M18T and M18MT RTRs!
Tower Hobbies
Logged in as Guest
Users viewing this topic: highspeeddirt
  Printable Version
More Resources on the
M18T
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> 1/16th, 1/18th, Mini & Micro RC Cars >> RE: Xray M18T and M18MT RTRs!
    Page: <<   < prev  6 7 8 9 10 [11] 12 13 14 15   next >   >>
    Login
    RE: Xray M18T and M18MT RTRs! - 6/30/2008 1:24:01 AM
    RC Huligan
    Status: offline
    I had a defective receiver on my XRAY NT18MT and RC America replaced mine for free. Of course, I confirmed it was defective first and mailed it back to them. Back in action now.
    _____________________________
    I help run RC XRAY, an online store where XRAY fans buy their RC cars & kits.
    (in reply to alex.guzun)
           Post #: 251
    RE: Xray M18T and M18MT RTRs! - 6/30/2008 9:02:30 AM
    alex.guzun
    Status: offline
    how does it act, when you have a faulty Rx
    just to let us know
    (in reply to RC Huligan)
           Post #: 252
    RE: Xray M18T and M18MT RTRs! - 6/30/2008 12:32:34 PM
    RC Huligan
    Status: offline
    quote:
    ORIGINAL: alex.guzun
    just to let us know
    It affected my steering mostly. The truck would jerk right randomly which made it difficult to troubleshoot. I had already replaced the diffs so that was eliminated as a source of the problem. We also switched radios and crystals. The truck wouldn't hold a straight line. We have 4 of the NT18MTs so I traded out the receiver tray from another truck and mine ran great.
           Post #: 253
    RE: Xray M18T and M18MT RTRs! - 6/30/2008 1:10:21 PM
    alex.guzun
    Status: offline
    amazing car... can't wait to get brushless later this year.
    Can't deside with combo should i buy: Sidewinder Micro, new Mamba Micro Pro or Xcelorin (it has bigger package). Probably it will be Xcelorin. Any one tried them both to compare?
           Post #: 254
    RE: Xray M18T and M18MT RTRs! - 6/30/2008 1:53:05 PM
    RC Huligan
    Status: offline
    I only have experience with Mamba and have enjoyed their products.
           Post #: 255
    RE: Xray M18T and M18MT RTRs! - 6/30/2008 4:43:57 PM
    DarkSoul Racing
    Status: online
    I have the Sidewinder 6800Kv kit in my M18t Pro, and it is pretty amazing. If you get the programmer, its amazing all the characteristics you can control, and how quickly it can all be set up. I highly recommend.
    Owner/Operator of DarkSoul Racing
           Post #: 256
    RE: Xray M18T and M18MT RTRs! - 7/6/2008 2:31:59 PM
    pete2222
    Status: offline
    Can anyone help me with this :
    On my M18MT, the screws that attach the engine mount to the chassis have eaten into the chassis. Therefore I can no longer ge the motor to hold the correct position. The spur and pinion gears keep moving apart and have both become badly worn. Is my only option to buy both a new chassis and spur gear? and if so, how can I prevent the screws damaging the chassis next time.
    Thanks for any advice.
    (in reply to DarkSoul Racing)
           Post #: 257
    RE: Xray M18T and M18MT RTRs! - 7/6/2008 8:26:39 PM
    rschoi_75
    Status: offline
    Have you tried using washers w/ the screws? It would be best to just get a new chassis, spur, and what ever else you think you need. Are you still using the stock composite mount?
    Of course I''ll have coffee... I always have coffee when I''m watching radar. Everyone knows that!
    (in reply to pete2222)
           Post #: 258
    RE: Xray M18T and M18MT RTRs! - 7/6/2008 9:18:28 PM
    pete2222
    Status: offline
    I have ordered a new chassis and spur now.
    As for the washers, I have tried it with some M3 washers. They did help a bit, but they bent and made it impossible to adjust after a while.
    Thanks for your help
    (in reply to rschoi_75)
           Post #: 259
    RE: Xray M18T and M18MT RTRs! - 7/6/2008 9:37:03 PM
    alex.guzun
    Status: offline
    anyone tried NT18MT chassis?
           Post #: 260
    RE: Xray M18T and M18MT RTRs! - 7/6/2008 10:13:04 PM
    DarkHorse
    Status: offline
    Yes it's an issue with the plastic composite chassis, especially if over tightened several times. I pinch up the screws snug and then CA glue the screws in place to stop any slippage. CA glue is quite brital and can be easily defeated if required later.
    Small issue but worth a mention. Also I noticed that an aging chassis can flex in this area, effecting the pinion mesh just by lifting the truck up in that area (brushless and hammered). Not that much flex but could be a problem if running a loose mesh and lots of power, could skip and strip damage pinion or spur. That's why sometimes when I set the pinion mesh in my hand and later find that on the road the mesh can be too tight. The longer m18t pro CF chassis does not flex in the same way.
    DarkHorse RC: Hornet X-3D, Ecureuil, Airworlf, X-ray M18T, Power & Setup Calculators ;) http://dhrc.rchomepage.com/
           Post #: 261
    RE: Xray M18T and M18MT RTRs! - 7/19/2008 4:01:47 AM
    patatchim
    Status: offline
    @DarkHorse thanks for your pm reply. I haven´t decided wich one i´m going to buy, the m18t or the m18mt.
    I´ve excluded the vendetta, because i do agree that the xray looks better, don´t know if its better, but it looks more professional.
    I have some questions you all xray owners don´t mind replying:
    - What servos fit on the xray m18t or m18mt?
    - The pinions that come with the kit, what is the size of the shaft they are made for?
    - I looked at the manual, and the diffs seem equal to the rc18t, do the xray suffer from the same diff problem?
    Mini titan, pico-z, mosquito | Tl-01b (bonzer edition :X) | Rc18b (bl and lipo) | Xray m18mt (bl and lipo)
    (in reply to DarkHorse)
           Post #: 262
    RE: Xray M18T and M18MT RTRs! - 7/19/2008 6:08:16 AM
    Mini_Me
    Status: offline
    quote:
    ORIGINAL: patatchim
    Hitec HS-82MG is popular.
    2mm shaft and a 48 pitch (not metric).
    Same size, but do not suffer issues as long as you break in the diffs per the directions. Xrays diffs also are ballraced internally versus the gear just spinning on the outdrive like the other you mention. This adds to their durability.
    M18/T FAQ available on http://www.teamxray.com/
    (in reply to patatchim)
           Post #: 263
    RE: Xray M18T and M18MT RTRs! - 7/19/2008 6:30:57 AM
    patatchim
    Status: offline
    Thanks for the reply!
    (in reply to Mini_Me)
           Post #: 264
