RE: Xray M18T and M18MT RTRs!
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> 1/16th, 1/18th, Mini & Micro RC Cars >> RE: Xray M18T and M18MT RTRs!
Page: <<   < prev  11 12 13 14 15 16 17 18 19 [20]
Login
RE: Xray M18T and M18MT RTRs! - 8/9/2009 8:49 PM
alex.guzun
Score: 100
Last Login: 11/26/2009
Status: offline
i have 9t/54t too, but have some chinese motors. Was thinking about to buy mamba, but as i can see it is 'the same' hot motor.
It costs me 15usd and it has heat sink built-in. So for my time to time bushing it is enough.
_____________________________
XRAY M18MT Gallery - http://www.flickr.com/photos/alexguzun/sets/72157606482630126/
ABEC35.com - Ceramic and Engine BEA
Hide Signatures
(in reply to DarkHorse)
       Post #: 476
RE: Xray M18T and M18MT RTRs! - 8/15/2009 6:34 PM
alex.guzun
Score: 100
Status: offline
just finished CVD in my Rhino3D
those will be manufactured soon, from ALU alloy.
Will post more pics and test results.
HiRes pics - http://www.flickr.com/photos/alexguzun/tags/cvd/
Hide Signatures
       Post #: 477
RE: Xray M18T and M18MT RTRs! - 9/1/2009 12:45 AM
pete2222
Score: 100
Last Login: 11/12/2009
Status: offline
It seems that the 9T is the only one that works for me, with my motor/battery combo. Can anyone advise if it's possible to buy just 9T pinion gears or do you have to buy the pack containing the other sizes too? Are there any other manufacturers that sell them cheper. Also, are the xray metal one much more durable and worth the price. Thanks.
Hide Signatures
(in reply to alex.guzun)
       Post #: 478
RE: Xray M18T and M18MT RTRs! - 9/1/2009 10:06 AM
alex.guzun
Score: 100
Status: offline
check - http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXFNJ8&P=7
as for metal, i'm using robinson pinions for my rock crawler.
Hide Signatures
(in reply to pete2222)
       Post #: 479
RE: Xray M18T and M18MT RTRs! - 9/1/2009 6:27 PM
DarkHorse
Score: 100
Last Login: 11/25/2009
Status: offline
M18MT has large wheel/tires, so I run an 8T metal pinion (2mm ID, 0.5 mod roughly 48pitch ) on the stock plastic 54T spur, makes more noise but it allows me to gear low enough for fast garden bashing on 3s with the little 5400Kv mamba. Probably max out around low 20s mph (at nominal voltage), flips and wheelies on demand in grass or street surfaces or spins like a demon on the loose stuff (it's a basher for sure ).
The metal spurs is even more noise (a few left on the shelf as spares) and the plastic spurs last so long, even using metal pinions as long as the mesh is pretty close. The problem with my aged M18MT is that the top deck and chassis can twist under power causing the pinion to skip, this eventually takes a tooth out and isn't long to a spur replacement. With the battered frame I just have to suffer a bit more noise with a slightly closer mesh. Note that I used to regularly power/torque flip upright from a roof tumble, now a days I don't do that so much.
module = 25.4 / pitch
48 pitch = 0.529 module
DarkHorse RC: Hornet X-3D, Ecureuil, Airworlf, X-ray M18T, Power & Setup Calculators ;) http://dhrc.rchomepage.com/
Hide Signatures
       Post #: 480
RE: Xray M18T and M18MT RTRs! - 9/1/2009 8:10 PM
pete2222
Score: 100
Status: offline
Thanks for the pinion advice. I've now got 2 M18MTs. I picked up a second hand one with lots of spares and a graphite chassis. Planning to stick with them for sometime, and want to keep them both running. The 9T pinion works really well for me, apart from wearing out, so it's great to have these options.
Hide Signatures
       Post #: 481
RE: Xray M18T and M18MT RTRs! - 11/5/2009 5:25 AM
Thomas P
Score: 100
Status: offline
Here is mine "non rtr"
My setup
klick on picture
http://rc-xtreme.blogspot.com/2009/11/setup-indorrs-halmstad-111-2009-118.html#links
www.rc-xtreme.blogspot.com = My Blogg
Xray M18TP Edition - eZrun - 40-50C 2s lipo
Hide Signatures
       Post #: 482
RE: Xray M18T and M18MT RTRs! - 11/11/2009 12:42 PM
kybowtie
Score: 100
Last Login: 11/24/2009
Status: offline
A buddy of mine just bought one of these and is wondering about a shock upgrade. I told him I would check out some info and get back with him. I run a detta st, so any info would be appreciated.
Hide Signatures
(in reply to Thomas P)
       Post #: 483
RE: Xray M18T and M18MT RTRs! - 11/12/2009 4:27 PM
alex.guzun
Score: 100
Status: offline
I have bought these: http://www.rcmart.com/catalog/rc-m18t-m18mt-3racing-alum-frontrear-damper-xray-m18t19bu-p-16581.html?cPath=595_1077_819
Hide Signatures
(in reply to kybowtie)
       Post #: 484
RE: Xray M18T and M18MT RTRs! - 11/12/2009 7:27 PM
pete2222
Score: 100
Status: offline
The stock ones are absolutely fine in my opinion. I do have some of these metal ones, but they don't make the car perform any better as far as I can tell.
Hide Signatures
       Post #: 485
RE: Xray M18T and M18MT RTRs! - 11/13/2009 5:09 AM
Thomas P
Score: 100
Status: offline
They have more tuning options, since they run 4 holes insted of 3 in stock plastic. But mostly the plastic ones are fine. Im running the metal ones 2 front and 2 rear, but im running the Buggy lid and non protecting Truck one.
Hide Signatures
       Post #: 486
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.797RCU1
