977 and Mini-LST2 batteries?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> MRC Charger Product Support (i.e. Super Brain, etc) >> 977 and Mini-LST2 batteries?
Page: [1]
Login
977 and Mini-LST2 batteries? - 11/12/2007 11:01:43 AM
xrapidx
Status: offline
Hi Guys
I'm new to this charger and was wondering if anyone could give me the settings to charging my Mini LST2's battery?
Its a small battery that looks like it has six little cells. (7.2V 1100mAh Ni-MH Battery Pack ).
I currently set the charger to 1amp, and then set the mAh on the charger to 1100mAh, and leave everything else as is? Is this correct?
Also, is it safe to just pop the battery in and charge it? Even if I can't remember if I've used it or not, I have 3 packs.
_____________________________
xRaPiDx
       Post #: 1
RE: 977 and Mini-LST2 batteries? - 11/12/2007 11:05:39 AM
xrapidx
Status: offline
Just checked, it is a 6-cell
xRaPiDx
(in reply to xrapidx)
       Post #: 2
RE: 977 and Mini-LST2 batteries? - 11/12/2007 3:40:14 PM
guver
Status: offline
I think you got it, and could reduce the threshold from 30 to 25 if you want also.
You'd probably not want to just plug it in because the default current is 3 amps and that's too fast for the smalll battery.
1 amp is better and 2 amps is considered the max a lot of times. 2 amps will cut the chargeing time in half and will degrade the battery quicker than using 1 amp.
you hear that silence?
       Post #: 3
RE: 977 and Mini-LST2 batteries? - 11/12/2007 7:25:23 PM
xrapidx
Status: offline
Great... what does the threshold do...?
Also, is it safe to plug them in even if they haven't been used, i.e. if I'm unsure if I've used them yet?
xRaPiDx
(in reply to guver)
       Post #: 4
RE: 977 and Mini-LST2 batteries? - 11/12/2007 7:36:13 PM
guver
Status: offline
The threshold (sometimes called mv, voltage drop-back, delta, negative delta, delta peak) is the amount of voltage drop that the charger looks for to tell when the batt is full for shutting off automatically. You can plug them in if unsure of the charged state and the charger should still shut off automatically.
       Post #: 5
RE: 977 and Mini-LST2 batteries? - 11/12/2007 7:48:15 PM
xrapidx
Status: offline
Thanks for all the help.
One last queston, if the battery is charged to full capacity, and I plug it in accidently, setting the charger to 1100mAh, charge rate to 1amp and push start, it will automatically pick up the battery is almost fully charged and shutdown fairly quickly?
xRaPiDx
(in reply to guver)
       Post #: 6
RE: 977 and Mini-LST2 batteries? - 11/12/2007 8:25:10 PM
guver
Status: offline
Yes, that's the qestion I thought you were asking really.
       Post #: 7
RE: 977 and Mini-LST2 batteries? - 11/13/2007 11:00:43 AM
xrapidx
Status: offline
It was... just making sure we were on the same page.
Thanks very much for your help.
xRaPiDx
(in reply to guver)
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.844RCU1
